Strange Problem at Cold Start
Old Mar 21, 2017 | 08:40 PM
  #31
Macrobb's Avatar
Macrobb
Next time you order parts, get a new mechanical lift pump, unless you replaced it recently.
Even if it hasn't 'failed', it seems like when they get old, the check-valves inside(which lets a diaphragm pump push fuel) get sticky and leaky and don't work so well.
Fine with the engine running, not so good at preventing leakdown overnight.
Old Mar 22, 2017 | 01:00 AM
  #32
Torsten.H's Avatar
Torsten.H
Hi Macrobb,
i have change the Liftpump before i build the Engine in, so it is 5 month old.
best regards
Torsten
Old Mar 26, 2017 | 08:48 PM
  #33
eagleye's Avatar
eagleye
Originally Posted by Macrobb
I just buy the cheapest kit off Ebay. Literally trying to find the worst one.
I have installed 3 or 4 of these so far with perfect results.
F250 F350 7.3L Ford Injector Return Line Kit 1987 - 1994 Diesel TRUCKS NON TURBO | eBay was the latest one I bought.
Thanks a lot!!! They're sold out now and I need to do my injector rings. Mine were leaking pretty bad on a long trip. Not at the beginning, but got worse over time. I need that kit. Interesting point is some kits have the drains on the side of the injector drain bowl and some are through the center for older 7.3 engines. Any difference and why? mine is of the older through the center type.
Can I just replace the o rings, bowls and return lines? I didn't think I had to remove the injectors to replace these isn't that correct? Thus I wouldn't need to use the copper washers.
Old Mar 26, 2017 | 09:00 PM
  #34
Macrobb's Avatar
Macrobb
Here's another listing for the same thing.
The different types are the early style, which uses through-the-center and 3/16" lines, and the later style, which uses along-the-side and 1/4" lines.
Either will work... But if it won't be too hard, the later-style seem to be a little easier to work with. The 1/4 barbs have multiple barbs(vs just one), and it just seems like the clamps are easier to get in place.
But it's totally user preference here. They both work fine in any application.
Old Apr 1, 2017 | 09:14 AM
  #35
Brian Gill's Avatar
Brian Gill
With a 6.9 idi, your filter head should be pretty simple looking, no fuel heater o-rings to worry about. Check the washers inside the line connections. Make sure your filter is sealing well.
On the feed to the high pressure pump, There's a check valve where the fuel line enters. Make sure that is good. Put a new one in if you're not sure. As long as that check valve is good, your supply lines will keep fuel in them. Although it's annoying, your return lines can spew fuel everywhere and the truck will still start and run. Some guys like to use clear line to connect the return system to the HP pump and to the filter head so that they can inspect for air intrusion. Not always foolproof, but helpful at times.
Good luck!
Get that supply side tight! Worry about the returns later!
idisam6.9
Sep 8, 2016 09:32 PM
Kma313
Mar 23, 2016 04:38 AM
TinyWonder
Nov 8, 2012 09:01 PM
Jayme Duty
21
Nov 7, 2010 09:46 AM
fury9
Jan 10, 2010 06:47 PM
