´56 ...not a "build thread" more a "modification thread"...
#332
If I remember correctly, the lower leg of the frame profile is longer than the upper one, this must be shortened, nothing else.
#333
The following users liked this post:
#334
My understanding is that the kits designed especially for our trucks, at least from the better brand name companies of which TCI should be one, are widened 4 inches from the stock Mustang II front end to accommodate the wider wheel track. Hopefully you didn't get a generic kit that didn't have this modification built into the crossmember.
#335
Happy new year Ladies & Gentlemen.
Started with the interior / inner rear Cab Panels,
the main / middle panel i build in one part, it was a cabinet back panel in it´s first life.
for the corner panels i started with templates from cardboard:
then bought pvc boards,
when I have shaped the plastic panels I will cover everything with carpet.
#336
#337
#338
#339
Received 4,244 Likes
on
#340
on
#341
#344
#345
