´56 ...not a "build thread" more a "modification thread"...
#226
#228
#229
Cheap material or?
I don't know. I certainly didn't think so. It was $750.00 to cover the seat, 5 -7years ago and he has a very good reputation. I think the issue is that as you bring the belt across your chest, the strap gets caught cross wise between the arm rest and that bead on the seat. It wears in one small area.. One doesn't notice the slight catch. The damage was done before I even realized what was happening. Same on the other side. Seeing as how it's a kinda daily driver, work truck. What is one to do. When I saw your pictures with belts hooked up very similar---thought I'd mention the issue. If you're not going to be using a bench seat. Probably not going to be an issue Just bad engineering on my part.
#230
Received 4,200 Likes
on
The following users liked this post:
#231
#232
#233
#234
Unfortunately we are not in California here, there´s no place to order stuff like that, so i built it yes.
A friend of mine burned the sides, the rest is just a bit cutting and welding ;-) i like jobs like that.
The following 2 users liked this post by ingo:
#235
The following 3 users liked this post by ingo:
#236
#237
#238
