Try removing the shroud and move it back as far as it can go to the engine...then bolt the fan on to the water pump...then move the shroud back over the fan and bolt it back on. That's the way I used to do it on vehicles with shrouds & mechanical fans.
That sounds like the best way to do it, as long as the shroud goes back far enough.
thats the reason why i built it in two pieces, move the whole shroud back will probably not
Thank you guys.
That's why I built the shroud in two parts, moving the whole shroud back maybe won´t help, I have to try to insert the fan blade between the box and the round part, otherwise I'll just have to loosen the radiator.
I´ll try tomorrow.
