Sponsored by: Real Truck
4r100 problem
Old Mar 7, 2017 | 02:55 AM
Woore's Avatar
Woore
4r100 problem
Hi all.
Recently I have had an issue with my auto which was just rebuilt. About 500 kays after i picked it up it shifts dangerously hard and immediately into all gears at around 20-40 mph, converter also locks immediately. The speed sensor in the box was replaced with the rebuild but I'm having it replaced again this thursday just in case.
Just for the record I cooked it on the beach a while back, the speed sensor was replaced with the rebuild as it was doing the above, the od light also flashes when this occurs, before and after the rebuild.
Prior to cooking it never had an issue.
Does anyone know of this issue or what could be causing it? I'm starting to worry it cant be fixed, have done a google and tried a couple of things mentioned.
Code says wiring issue associated with speed sensor in box.
Any help appreciated, cheers, Wayne.
Old Mar 7, 2017 | 03:31 AM
seville009's Avatar
seville009
If you paid someone to do the rebuild, take it back to them and have them look at it.
Old Mar 7, 2017 | 03:34 AM
Woore's Avatar
Woore
Its going back on thursday, i can just see it being a bit of a pain to diagnose.
Old Mar 7, 2017 | 05:34 AM
meborder's Avatar
meborder
If the OD light flashes, there are codes stored.
Those codes will steer you in the direction of the problem.
Old Mar 7, 2017 | 05:46 AM
Woore's Avatar
Woore
Yep, the Code says wiring issue associated with speed sensor in the gearbox.Just hard to know where or what exactly.
Thanks.
Old Mar 7, 2017 | 08:13 AM
mueckster's Avatar
mueckster
What is the code? Can't help, if we don't know what it is.
Old Mar 7, 2017 | 02:37 PM
Woore's Avatar
Woore
I'll grab it tomorrow, but it was the wiring issue code with the speed sensor.
Old Mar 7, 2017 | 03:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are three speed sensors, plus one on the engine. Just saying "speed sensor" isn't very helpful.
Old Mar 7, 2017 | 03:24 PM
Woore's Avatar
Woore
Ok, didn't realise, the first time it was the sensor on the back of the box, will find out, thanks.
andstal
Escape & Escape Hybrid
Sep 10, 2014 08:09 AM
triggernut7788
May 18, 2012 11:09 AM
Olds_442
Sep 4, 2007 05:02 PM
matttt74
Apr 13, 2004 09:52 AM
ctn8iv
Dec 2, 2003 11:07 PM
