Tie rods pooped the bed
Old 03-02-2017, 06:03 PM
Dude-Ford's Avatar
Dude-Ford
Dude-Ford is offline
Anybody got a part number for some solid ones that will last? Here's a nice video of the new popping noise I hear.
Old 03-02-2017, 08:00 PM
F350-6's Avatar
F350-6
F350-6 is offline
I don't have the part numbers handy, but MOOG makes some regular duty (worthless) ones, and some heavy duty ones that work pretty well.
Napa's private label stuff is (was) Moog and the standard duty ones didn't last at all. The heavy duty ones, which you can see a big difference in when looking at them side by side, did work well.
Old 03-02-2017, 08:36 PM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
Original Motocraft at the bottom of the list. Check your year model
2000 FORD F-250 SUPER DUTY 7.3L V8 DIESEL Turbocharged Tie Rod End | RockAuto
Old 03-02-2017, 09:55 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
If you order Motorcraft from Rock-auto it will not come with a nut or castle cover for the cotter pin, I went through this not long ago and had to source through my dealer. The nut on the offer tire rod didn't line up correctly either.
Old 03-02-2017, 10:43 PM
Dude-Ford's Avatar
Dude-Ford
Thanks y'all. Now I'm realizing I don't have the money to fix it fast cuz I'll kick my self for not getting the heavy duty ones. Think it'll do any damage other than to my ears and temper?
Old 03-03-2017, 02:43 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
You could kill your self if it lets loose. Hows that.
Old 03-03-2017, 04:38 PM
Dude-Ford's Avatar
Dude-Ford
"That" would be terrible. Think I'll park it for now.
Old 03-03-2017, 11:10 PM
Sous's Avatar
Sous
Sous is offline
Received 4,466 Likes on 2,855 Posts
Reps sent for getting right to the point and the best answer of 2017 so far...
Old 03-03-2017, 11:27 PM
Bonanza35's Avatar
Bonanza35
God bless,
Old 03-05-2017, 12:05 AM
Bently_Coop
After seeing this thread and video I had been hearing excessive klanking similar to what OP showed and have to replace my drag link and center link. Originally I was leaning towards the springs which will also be replaced down the road along with passenger tie rod at a soon but later date. Going Motorcraft from Horizonpartsguy Monday morning.
Old 03-05-2017, 04:24 PM
Dude-Ford's Avatar
Dude-Ford
Well installed the new ones and my ******* accidentally moved the steering wheel during the install, my length was pretty dang close to the stock length and now my steering wheel is sideways. Will an alignment fix this or do I need to crawl back under and mess with it.
like straight is completely sideways.
Old 03-05-2017, 04:41 PM
Sous's Avatar
Sous
Sous is offline
There is a joint in the middle that has 2 screws and a clamp. Loosen the screws, rotate the clamp until the wheel is straight. Tighten the 2 screws and take it for a short test drive.
Rinse and repeat until you are happy with the wheel placement.
Old 03-05-2017, 04:57 PM
countrycar's Avatar
countrycar
countrycar is offline
This should help you fix it. When I adjusted mine, I attached a bright green level (on center) with a bungee to the steering wheel. I attached it up high to the steering wheel so that I could see it from down in front of the truck. This helped me to get it close to center and avoid having to get in and out of the truck to check it as much. After this, it just required some small increment adjustments to get it right on. Maybe someone has a better way of doing this, but it works great if your alone.
On Edit: Thanks to the member (Quietman) for posting up this procedure here on FTE..
https://www.ford-trucks.com/forums/7...with-pics.html
Old 03-05-2017, 05:39 PM
Dude-Ford's Avatar
Dude-Ford
Thanks dudes! All good now, alignment shop can take care of the rest.
black_silver_95s
1999 to 2016 Super Duty
01-31-2012 10:16 AM
Ford4Life7.3
11-10-2011 06:18 AM
arkredneck
11-09-2011 01:34 PM
mgriffin
29
01-23-2003 01:03 AM
Quick Reply: Tie rods pooped the bed
