Tie rods pooped the bed
I don't have the part numbers handy, but MOOG makes some regular duty (worthless) ones, and some heavy duty ones that work pretty well.
Napa's private label stuff is (was) Moog and the standard duty ones didn't last at all. The heavy duty ones, which you can see a big difference in when looking at them side by side, did work well.
After seeing this thread and video I had been hearing excessive klanking similar to what OP showed and have to replace my drag link and center link. Originally I was leaning towards the springs which will also be replaced down the road along with passenger tie rod at a soon but later date. Going Motorcraft from Horizonpartsguy Monday morning.
Well installed the new ones and my ******* accidentally moved the steering wheel during the install, my length was pretty dang close to the stock length and now my steering wheel is sideways. Will an alignment fix this or do I need to crawl back under and mess with it.
like straight is completely sideways.
This should help you fix it. When I adjusted mine, I attached a bright green level (on center) with a bungee to the steering wheel. I attached it up high to the steering wheel so that I could see it from down in front of the truck. This helped me to get it close to center and avoid having to get in and out of the truck to check it as much. After this, it just required some small increment adjustments to get it right on. Maybe someone has a better way of doing this, but it works great if your alone.
On Edit: Thanks to the member (Quietman) for posting up this procedure here on FTE..
https://www.ford-trucks.com/forums/7...with-pics.html
