Help with gear contact pattern
Old Feb 8, 2017 | 09:47 PM
farmerchad's Avatar
farmerchad
hello again, got things shimmed pretty close, I'm using same used gears I took out, same .030 pinion shim that was there, about .010 to .012 backlash. Contact on coast side looks about in the middle flank to face, drive side looks low toward flank. I've read not to go by drive side pattern on used gears, just the coast side.
Anyway, here are pics for any advice.
Old Feb 8, 2017 | 10:48 PM
P.Bronner's Avatar
P.Bronner
I agree with what you're saying BUT... did you pattern it prior to teardown? Based on what I'm seeing, I think you're at the "happy medium" right now. If anything will get a person pulling their hair out, this is it. Welcome to the black art of differential work. I've run into the situation where I had what I thought was the perfect gear set-up only to have it whine somewhere, and then fix it by adjusting the pattern to something less ideal. I think you're good where you're at.
Old Feb 9, 2017 | 04:49 AM
farmerchad's Avatar
farmerchad
No, I didn't check pattern before tear down, I did think about it but thought since my old pinion bearings were so loose, I might not get a consistent pattern. Oh well.
Guess I need to get certified in the black arts..
Old Feb 9, 2017 | 09:20 PM
steve(ill)'s Avatar
steve(ill)
im a firm believer that all bearings are made to a TIGHT SPEC... So if you change the bearings and REUSE the gears, the pattern should be real close to what the factory setup... assuming you have good backlash.... I say your good to go !
Old Feb 9, 2017 | 09:33 PM
P.Bronner's Avatar
P.Bronner
Yes, bearing specs are very tight. I'd put it together just like it came apart. Every diff. adventure I've embarked upon involved re-gearing so of course it's a fresh start scenario - sort of. I've always had the original pinion shim work (pinion specs are pretty tight too, its the housing that varies). If you can play a tune with the gas pedal, you know you screwed up !!
Old Feb 10, 2017 | 04:41 AM
farmerchad's Avatar
farmerchad
Yep, I'm putting it together the way it is, only thing I did was shimmed closer to pinion to tighten up backlash, but ended up with about .555 total carrier shim, within .001 or .002 of original set up. Backlash is at about .012
RTM
2009 - 2014 F150
20
Sep 10, 2019 04:04 PM
kc7smo
May 18, 2017 11:37 AM
Resto
17
Jul 28, 2016 07:15 PM
fearfactory
Mar 8, 2006 06:56 PM
zsir
Nov 19, 2005 05:48 AM
