Sponsored by: Real Truck
Tailgate theft
Old Feb 21, 2017 | 07:26 PM
  #31
Pshicker's Avatar
Pshicker
Originally Posted by SnowPlowDriver
If you use a hose clamp,open the tailgate to a 45 degree angle and have a helper tighten the clamp from under the truck. The thief wiill then need a helper also.
This is what I did. Easy and it'll slow em down. I also keep mine locked all the time. I may consider the Pop & Lock also. Too bad we have to worry about the bad guys. They cost us money in most aspects of our lives....
Old Feb 21, 2017 | 08:20 PM
  #32
I.B. Washincars's Avatar
I.B. Washincars
Most of this type of criminals are just stupid and lazy. Throw something into the mix that they don't expect. If it takes them longer and most likely aren't prepared for the surprise, most likely will move on to an easier mark. You don't necessarily have to outrun the bear...
Old Feb 21, 2017 | 09:38 PM
  #33
bayou barataria's Avatar
bayou barataria
ok thanks duece, I will check it out.
Old Feb 21, 2017 | 09:50 PM
  #34
P.Bronner's Avatar
P.Bronner
Thats exactly what I did. Also keep it locked when you're not actively using it. -- OR- Get a dog crate and take the gate/door off. Place it so the tailgate, when closed, forms the gate. Now put a badger in the crate.
Old Feb 22, 2017 | 06:34 AM
  #35
Poncho450's Avatar
Poncho450
Originally Posted by thomabb
A zip tie around the right hinge is all you need. Tailgate thefts are rampant because they are easy to lift off and carry away. The thief will try once or twice to lift your gate off and then walk away.
Personally, I can afford $16 for something that can't easily be snipped away. Not all thieves are that lazy. Some might take the extra time if they think they have it.
RA041024
6.4L Power Stroke Diesel
Feb 28, 2024 11:36 AM
PackerBacker_TX
Jul 15, 2017 11:16 AM
BigF350
6.7L Power Stroke Diesel
63
Jan 26, 2014 12:30 PM
madsonp
Feb 13, 2013 05:42 PM
DieselOwnerNow
Jan 22, 2008 12:45 PM
