front leveling kit
Old Feb 8, 2017 | 07:11 AM
  #31
jimzpsd's Avatar
jimzpsd
Originally Posted by Fittycal
Jimzpsd, Yes did the install myself and I am referring to track bar relocation bracket (same Ready Lift bracket as 2016 model year). Pretty easy install. Very frustrating though because the people I purchased the kit from (Stage 3) said I needed nothing else. But when I called to inform them of the axle shift to the driver's side, they had no idea it happened on their own project truck until I called. Nobody seems to know anything about these trucks yet.
I saw a ton of videos too about the installation, seems too easy to be true and this is what prompted my question and find some hidden details. Thanks.
Old Feb 8, 2017 | 07:12 AM
  #32
jimzpsd's Avatar
jimzpsd
Originally Posted by Hackenbush
Sweet, nice price too. Thanks
Old Feb 8, 2017 | 07:55 AM
  #33
EpicCowlick's Avatar
EpicCowlick
Quick question for those who are installing the trac bar drop brackets. Doesn't the track bar nut have to be torqued to something like 400 lb ft? How are you doing this? Do you have shops that have this equipment or are you using a torque multiplier?
Old Feb 8, 2017 | 08:09 AM
  #34
user 474747383's Avatar
user 474747383
I have a 3/4" drive that goes to 600ft left from my now retired, spring/font end shop I owned for 27 years.
Old Feb 8, 2017 | 08:10 AM
  #35
kylant's Avatar
kylant
the mount bolts are only 14mm. the torque on them was 117ft/lb if I remember correctly.
the actual track bar bolt is 406 ft/lb. my torque wrench only goes to 250. I used that, then a breaker bar as tight as I could possibly go (doing a leg press on it )
I have no idea what the actual torque is, but I am guessing it is sufficient
Old Feb 8, 2017 | 08:14 AM
  #36
bikerman5345's Avatar
bikerman5345
The torque i believe is 406ftlbs i would have to look at the sheet again. I have a torque wrench for that size so it was not an issue for me. If you don't have one i would seek out someone or a shop that does have one to have that bolt torqued. Other than that its easy to install.
Old Feb 8, 2017 | 08:17 AM
  #37
user 474747383
The bushing will let you know soon if the torque wasn't enough.
Old Feb 8, 2017 | 09:26 AM
  #38
EpicCowlick
That's what I thought. I have a 5 to 1 multiplier in my toolbox that I've never used. It's about time.
shark1979
6.7L Power Stroke Diesel
23
Dec 8, 2013 09:46 PM
bebeard
Dec 9, 2011 05:21 PM
parkland
6.4L Power Stroke Diesel
18
Apr 23, 2011 09:28 PM
kaipo
May 1, 2006 09:02 AM
PHS79
2004 - 2008 F150
Mar 24, 2006 11:38 AM
