Sponsored by: Real Truck
adding a leveling kit to my 6" basic kit
Old Apr 15, 2006 | 01:37 PM
kaipo's Avatar
kaipo
I installed a 6" basic kit to my 05 f-350. I had a leveling kit before that. Anyone know if I could add the leveling kit to make it a little higher? If not, what can I do to go higher without having to purchase a new lift kit?
Mahalo,
Kaipo
Old Apr 15, 2006 | 07:49 PM
mattd17's Avatar
mattd17
well, since you have coil springs up front, i would say yes, you could add the leveling kit to it... however... i would not recommend this. it changes other things also..such as shock travel distances, brake lines, trac bar, etc. does the truck sit fairly level right now? if so, then you would need to compensate in the rear also. the easiest and cheapest way to get the extra inches, is to add a body lift. you can go up to 3 extra inches, for just a few hundred dollars. some people are not fans of them though. they are fine for a street driver, but any serious off roader would go just with susp lift. then one more issuse comes into play.... if you do go a few more inches, yes you will get more wheel clearance, and that could make it look "goofy". goodluck !
Old Apr 19, 2006 | 04:39 AM
kaipo's Avatar
kaipo
Thanks for the info mattd17.
Old Apr 19, 2006 | 09:14 AM
bullitt5244's Avatar
bullitt5244
hey i did that to miy truck i have a 06 c/c diesel with the 6 inch superlift and it works fine any ques let me know ...
Old Apr 30, 2006 | 01:12 PM
kaipo's Avatar
kaipo
Thumbs up
I figured I'd give it a try and it came out pretty nice. I'm okay with the big gap between the tire and well, I like that look. Check it out.
Old Apr 30, 2006 | 04:38 PM
mattd17's Avatar
mattd17
looks really nice....i am courious how it would sit with an extra inch or two in the rear. i love the color too !!!
Old May 1, 2006 | 09:02 AM
bullitt5244
looks good kaipo i also did a add a leaf in the back to make it sit level and put on 38.5 by 14.5 pro comp x terrains i will try to post some pics
kaipo
Dec 31, 2006 10:21 AM
kaipo
Apr 19, 2006 04:35 AM
gui88ford
1997 - 2003 F150
Jan 28, 2005 09:15 PM
