LIFT KIT, or blocks and leveling kit??
So i've been thinking of a lift kit & 37" tires...
Then someone told me all you need to run 37"'s is a 2" leveling kit.
Then I was thinking it will look stupid with weight in the back as the front will be pointing up....
THEN I started thinking, why not install a 2" leveling kit in front, and a 2" block in the back?
The truck should sit as it does now, only 2" higher, and be able to run 37" 's.
Also the cost is much lower than buying a lift kit.
Thoughts?
Thoughts?
Your new truck isn't in your sig so I didn't know if you had a F250 or 350...
I did the ICON 2.5 Stage I leveling kit on my buddy's F350, along the OUO traction bars and ICON's adjustable track bar. I do NOT want to cause any issues with supporting vendors, they're invaluable to this site, but just for informational purposes HERE'S where we bought the system...
He's running legit 35s on the stock 18s and the stance and look couldn't be more perfect, at least in our opinion!
That's a whole lot more expensive than just buying some spacers, but the difference in ride quality between a truck with just spacers and this truck is completely night and day. This ICON kit is often commented to ride like a Cadillac and since I just came out of an '07 Escalade ESV, with the exception of the firmness provided the additional leaf springs that the F350 has (and the F250 doesn't) it did make for an exceptional improvement in ride quality.
If you tow, use the truck for work, etc. then you might want to consider a kit like ICON's over just some leveling spacers or the like. On my '10 F250 I'm likewise using the ICON 2.5 kit with some additional upgrades over the Stage I...
Hope this helps, good luck!
I own a 08 250 C/C SWB FX4 and I put the pro comp 2.5 spacer on the front and pro comp 4" block in the rear. I liked the pro comp block best because it's OEM style. They are a bit pricey, though. Replaced the Ranco's with the Pro Comp 9000's. My truck sits with a 1/2" rake in it now and I love it. If you are towing you may want to use a 5" block in the rear. I'm running Nitto's 295/70/18's, which are 34.5" on stock wheels. They are more narrow than a 35x12.5 but have a 4090lb. rating. Most 37's aren't a true 37" and will probably fit without a problem. Think I paid around $1900 for everything.
I wouldnt run 37's on any less than a 6" lift. Thats just my opinion since I only like low offset rims that stick out alot and require more clearance and I also hate the look of a stuffed tire (no fender clearance). I'm sure you could pull off 37's on a 4" lift but you would probably have to trim a little.
37's fit fine!
Speaking of which, what's the width on those 37s...?
The truck sways and bobs pretty good in the ruts on the beach with the camper loaded. I haven't had any issues with bumper or flare contact as yet.
Of course it's not like romping around in a sand pit or the woods at pretty good speeds. I won't be doing that so I guess the setup is good for my needs.
Sorry... haven't been by the computer for a couple of days! The wheel are Helo HE842's in 17X8 - "0" Offset and 4.5" backspacing. Longview1 was right - the tires are Toyo Open Country MT's in 37X13.50R-17's.
Personally, as a biker, I'm NOT a fan of gigantic tires sticking out past the fender with no flares and/or mudflaps...it's not cool. If anyone thinks it is, go to your local batting cage and stand in front of the pitching machine set to "fastball"!
