Engine Swap
Old Jan 13, 2017 | 07:53 AM
  #31
knottyrope's Avatar
knottyrope
yes it could cause a knock sound, pull it and inspect maybe it is loose and burnt
swap to other side and see if issue follows
Old Jan 13, 2017 | 08:26 AM
  #32
ChrisMelton78's Avatar
ChrisMelton78
When I pull the two injectors, is there anything that I'm looking for in particular?
Old Jan 13, 2017 | 08:36 AM
  #33
knottyrope's Avatar
knottyrope
see if copper washer is present and lower oring is present
show us a pic of them too
Old Jan 13, 2017 | 11:12 AM
  #34
ChrisMelton78
So, there's a chance that it could have chewed up the washer? That can't be good.
Old Jan 13, 2017 | 11:24 AM
  #35
knottyrope's Avatar
knottyrope
if its loose, the copper washer burns up and can burn up the injector after
arguing about it wont do anything, go yank it out and look
Old Jan 19, 2017 | 07:32 PM
  #36
ChrisMelton78
So, today I pulled injectors 1 and 3. As I was preparing to loosen the lower 8mm bolt holding the injector in, I found that it was barely hand tight. I did my best to torque them to 120 in/lbs when I reinstalled them after installing new seals, but all I had at the time was my Harbor Freight torque wrench. Should it be that loose? Could that cause a problem? Also, after I pulled the injectors today I could see some trash down in the injector bore. Could any of this cause the blue smoke issues?
See the pictures that I took of the injectors too.
Old Jan 20, 2017 | 08:02 AM
  #37
knottyrope's Avatar
knottyrope
define trash in bore, if its just carbon then you had a leaking copper washer from injector being loose and caught it fast.
re torque injectors, run with valve covers off and see if all spurt same amount
I had two get loose on my at 120, some have said to use 140 in pounds or set them when engine is hot
Old Jan 20, 2017 | 09:52 AM
  #38
ChrisMelton78
Well, I just looked down into the bore and I could see a shoe, a skull, two sets of bones, a old tire, and 3 fishing lures.
It just looked dirty. It's probably just the carbon like you said.
Alta
Dec 1, 2013 05:19 PM
1979FORD400
62
May 23, 2013 04:50 PM
jdb111485
Aug 3, 2010 11:48 AM
TourqueRise
Apr 23, 2009 08:03 PM
richardmiller
Mar 20, 2008 06:39 PM
