Ignition coil /wiring
Old Aug 27, 2003 | 11:12 AM
dablack's Avatar
dablack
I'm trying to track down a no start problem. You can see the full thread under the 385 section. Anyway could you let me know how it is hooked up. I've got a green wire that goes under the dash. A red wire the comes from under the dash and a black wire that is hooked to the distributor. I am assuming the red goes on the positive side, green on negative and black (from distibutor) on negative. This is a points distributor.
Thanks
Austin
Old Aug 28, 2003 | 12:09 PM
dablack's Avatar
dablack
I can't believe one guy won't run out to his truck real quick to check the wiring on the coil that is right in front of the engine. Come on guys....help me out.
Thanks
Austin
Old Aug 28, 2003 | 12:19 PM
MuchToMyDelight's Avatar
MuchToMyDelight
I have a pertronix, so I am not 100%, but in the instruction pamplet, it says that the 8 volts from the ignition switch and ballast resistor (or 12 volts without the ballast resistor) goes to the + side of the coil, and the points attach to the - side.
Old Aug 28, 2003 | 03:21 PM
jas88's Avatar
jas88
I don't know what that green wire is for, but there should not be anything hooked to the negative side of the coil except for the black wire coming from the points.
Old Aug 28, 2003 | 03:25 PM
Comegetsome's Avatar
Comegetsome
Just popped the hood on my '67 and black to (-) and red to (+). I don't have a green so I couldn't tell you what that's about.
Old Aug 28, 2003 | 07:42 PM
jds1971's Avatar
jds1971
Is that green wire supposed to go to the temp sender right behind the distributor? Could go to the oil sender also.
Joe
Old Aug 28, 2003 | 08:38 PM
DuckRyder's Avatar
DuckRyder
oil sender n mine is white wire, green is on the temp sender.
Old Aug 29, 2003 | 07:10 AM
dablack's Avatar
dablack
Thanks guys. Now I'm can't wait to run home at lunch and see if my truck will start! I hope that is the problem. I don't know what this green wire could be? The temp sender is already hooked up. It runs into the cab through the same hole as the temp sender wire and others. I will get under the dash and see where it goes from there.
Thanks alot
Austin
Rockworthy
Aug 15, 2015 09:24 PM
HillBillyBuddha
Apr 30, 2013 01:28 PM
daniel1982
Apr 26, 2011 04:41 PM
chaser1602
Aug 5, 2009 11:16 AM
1972-34ton
Jul 27, 2009 10:47 PM
