Front differential / axle vent location?
Old Jan 1, 2017 | 05:10 PM
nddragon01's Avatar
nddragon01
Looking to change out my front differential cover tomorrow, cover is pitted, rusted, corroded, and leaking at the seals. While under there I want to inspect the vent for the axle and differential (and replace if it's clogged - which I believe is leading to the seal leaking). Can anyone give some advice as to the vent tube location on the front axle? Thought I read somewhere it was on the cover itself, turns out that's a negative.
Thanks!
Old Jan 1, 2017 | 07:39 PM
steve(ill)'s Avatar
steve(ill)
normally there is a drilled and tapped hole near the top on the center case, not the cover. Usually some type of banjo fitting or could be a threaded nipple with hose fitting and then a rubber hose up to the frame with a clip.... sometimes they poke INSIDE the frame to keep the end away from dirt and water.
Old Oct 19, 2023 | 08:47 PM
Rwbourgeois66's Avatar
Rwbourgeois66
1st Gear
Front differential vent location
Thanks!
I've been looking for 3 days. I have a certified mechanic that tells me the same thing it's on the front tip for you too I cooked that lot of hoes attaining there not plugging anything running as far as I could everywhere. There is no freaking vethat you are on that ****ing then. So where the hell does that freaking breather line go? So I challenge anybody that says they have one. Send a picture and prove it.
Old Oct 21, 2023 | 03:43 PM
WWR's Avatar
WWR
It's kinda more on the RH "tube". If the hose has come off it just looks like a nub, not so easy to see as it kinda sits in a counterbore
Old Dec 6, 2024 | 06:41 AM
rsylvstr's Avatar
rsylvstr
can we add a check valve to these to prevent water intrusion from pressured car washes?
or extend it?
Old Dec 6, 2024 | 08:54 AM
WWR's Avatar
WWR
or extend it?
Just get the GM rattle cap breathers and extend it. They're not a check valve but offer a degree of passive sealing. Try part #25892279
You don't want a true check valve because it needs to breathe in BOTH directions-- think about your lungs as you inhale AND exhale.
RossTheBoss
Aerostar
May 16, 2018 03:20 PM
jakeharp
Jun 20, 2017 07:02 PM
spaytons
Mar 16, 2014 08:50 AM
Buzzman
Aug 15, 2007 10:22 PM
skeeter4x4
Aug 1, 2006 10:03 AM
