Aerostar Ford Aerostar
E-AWD Dana 28-2 Axle Leak Tube Vent FYI
Old 05-16-2018, 10:45 AM
RossTheBoss's Avatar
RossTheBoss
RossTheBoss is offline
Exclamation E-AWD Dana 28-2 Axle Leak Tube Vent FYI
Last night I went to top off my front diff because of a leak I described here
I was able to pump in about 3/4 of a quart before full and then noticed that there was a vent hose hanging near the axle tube.
Come to find out this is the vent hose for the front differential and with it disconnected there is a 3/8" hole on the tube open to the world.
I reconnected it and put the fill plug back in place.
I'll check it again in a couple of weeks but this is probably the main source of the leak.
I'm still planning on doing the axle shaft bearings, tube seals and pinion seal described here
CV/Axle shaft flange connection on the right
close up of reconnected vent
Old 05-16-2018, 03:20 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
That little plastic nipple just pushes into the hole in the axle housing, held in by friction. If it's leaking, you can try wrapping some teflon tape around it before pushing it in.
Several years ago, I was advised to replace the atf in the front axle with gear lube. Terrible idea. The gear lube got a lot hotter than the atf as it was so much thicker, and expanded out the vent hose; it pushed its way all the way up the rubber hose to where it ended in the frame, and leaked all over the frame. I have to keep replacing the lost gear lube with atf, until it stops.
Yetti
01-24-2019 11:19 AM
Piolet
09-18-2011 09:00 AM
Big Sky
1999 to 2016 Super Duty
06-24-2011 08:39 PM
78fordranger
1978 - 1996 Big Bronco
09-27-2006 03:45 PM
mnm99
04-03-2003 04:31 PM
Quick Reply: E-AWD Dana 28-2 Axle Leak Tube Vent FYI
