9in axle vent fitting
Old Aug 13, 2007 | 08:14 PM
Buzzman's Avatar
Buzzman
I pulled the fitting out of the axle housing to clean it and could not see through it. I chucked up a small pilot sized drill bit and tried to clear it, but it seems to be not machined all the way through. So before I drill it out, what am I missing here. Are they supposed to have the same size I.D. through?
And another short one, while I remember it. Are the gaskets to the backing plates necessary, if they are, it must be for keeping out water, no? Mine didn't have any gaskets, and noticed some rust between the axle seal and housing.
Old Aug 14, 2007 | 06:31 AM
cujo8's Avatar
cujo8
On my 77 F150 9" rear axle the vent hole went all the way through. On mine the vent tube was also the bolt that held down the rear brake distribution block.
Old Aug 14, 2007 | 06:28 PM
Buzzman's Avatar
Buzzman
Mine is the same, but that part that is used to hold down the brake tubing tee, isn't bored completely through. The piece looks like it is machined out of 9/16 hex stock, turned and threaded 3/8-24, and bored 9/32 on the end going into the axled housing. It is bored 3/16 on the end that the vent hose goes over, but the bores do not reach each other. I know this isn't really a big deal, but I was wondering if anyone else has seen this before. There was plenty of gear lube in it and no leaks.
Old Aug 15, 2007 | 03:44 PM
rebocardo's Avatar
rebocardo
It is suppose to be a vent, not a straight hole, so it has baffles to help prevent water from coming into the axle (air pressure) and grease from leaving with the air when it gets extremely hot.
That being said, when mine have been gunked up, especially the front axle, I have drilled them out (1/4"?) since I run my vent lines up into the frame or body and put a few loops or curves in them.
You can buy them new at NAPA too!
In short, if it is clogged and can't be cleaned, drill it out, and don't worry about it. I never did and had no problems. imo, A clean straight through vent on an axle is better then a clogged factory vent.
Old Aug 15, 2007 | 10:22 PM
Buzzman's Avatar
Buzzman
Okay, thanks. I will take care of it.
unknowing
Dec 1, 2015 08:44 AM
arctic_driver
Mar 22, 2015 04:38 PM
Jerry Chaney
May 2, 2014 10:53 AM
BDawg171
17
Apr 8, 2014 01:09 PM
