D60 inner axle seals
Old Aug 1, 2006 | 09:55 AM
skeeter4x4's Avatar
skeeter4x4
1996 F350, PSD, Crew, 128,000mi
I lost both inner axle seals on my D60 front end recently, in fact, the seals failed within a week of each other. This also occured during a recent hot spell. My best guess would say that they failed because of a plugged vent tube. It's going to be a lot of work to replace the seals and I don't want to do the job twice. Are plugged vent tubes common for this axle? Can the stock vent be upgraded in any way? I want to fix the source of the problem before I tear it completely apart and replace the seals. Thanks.
Old Aug 1, 2006 | 10:03 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
On highway trucks I've just run a hose off the diff up into the engine bay or along the frame rail and have 8 or so inchs hung over slung down toward the ground, never had a problem with plugged vents
Yeah, a plugged vent will deffinitly blow oil out your seals, once in a while you can clean them out to relieve the presure and sometime the seal will stop leaking. Just food for thaught
Knewstroke97
Nov 28, 2014 07:43 AM
djmac
Apr 15, 2008 01:52 PM
mikefender
Apr 21, 2007 09:16 PM
skeeter4x4
Aug 2, 2006 08:41 PM
Rob.D
Feb 6, 2005 03:22 PM
