Crank no start.
Old Nov 25, 2024 | 06:03 PM
Jadco's Avatar
Jadco
8th Gear
Crank no start.
I have an 07 f150 5.4. It has 330000 miles on it and runs great , that is up until yesterday. I got in it to go somewhere and it just cranked like it was out of gas.
what I’ve checked are these.
1 fuses, all good
2 just listened for fuel pump operation, all good but I haven’t checked fuel pressure
3 put a scanner on it ,key on truck not running, and pulled these codes.
P1000
P1288
P1397
P1000-FF
Basically sounds as though it’s a PCM problem?
How does that just break? I figured I would have some sort of warning like rough running, poor shifting etc. I did a visual of the engine and everything seems to be in order.
i did notice when I was cranking it I was getting an electronic tic coming from either the fuse box or somewhere on the right side .
Any input would be greatly appreciated. Thank you.
Old Nov 28, 2024 | 06:57 AM
redfishtd's Avatar
redfishtd
Try to start it with starting fluid . That should let you know if its a lack of fuel . I'm not sure your cranking has been hard on battery and caused those codes with low voltage . This time of the year bad batteries show up , cold does not kill batteries heat of summer does , But cold reduces the flow out of a weak battery .
The major item that causes a lack of fuel is the fpdm module on the rear axle . You must inspect it for corrosion as it is aluminum backing sitting on steel and they eat each other . Then water gets inside module . New ones come with plastic spacers to stop metal contact .. They have a high fail rate .
You can turn key on with scanner attached and it will tell fuel pressure on rail . Torque pro $5 app on an old android with a cheap amazon bluetooth reader will tell you lots of stuff .
If you search fpdm on this site tons of pics and info will pop up . As well as a sticky at the top of page .
Old Dec 7, 2024 | 09:38 PM
Fifty150's Avatar
Fifty150
Suck Bang Blow
You need fuel, air, and spark.
Is the engine deprived of air or fuel?
There are a lot of troubleshooting tutorials....... you just have to look for them.
83K views1 year ago
REV ALASKA
Diagnosing a 2004 F150 no crank, no start issue. A DIY solution to a PCM power problem. #revalaska #mechanic #diy #pcm #ford ...
352K views2 years ago
FordTechMakuloco
In this video we show you in detail how to diagnose a faulty starter on your Ford F-150. The only remanufactured starters I ...
6 chapters
Intro | Starte
626K views3 years ago
South Main Auto LLC
In this Video I have a look at a 2007 Ford F150 5.4 that was towed in as a no start. After a quick look we discovered that the truck ...
98K views2 years ago
THEMOWERMEDIC1
PLEASE CHECK OUT MY MUST HAV
cames645
2009 - 2014 F150
Oct 23, 2021 08:15 PM
perplexd
2009 - 2014 F150
Aug 3, 2021 05:49 PM
90supraw
Jun 17, 2021 02:55 PM
Michael DeWiese
Dec 23, 2015 07:49 AM
rock2610d
Modular V8 (4.6L, 5.4L)
Mar 18, 2013 07:44 AM
