Pulling someone out of snow question
And pull using a FORWARD gear with your rig........the ring and pinion are much weaker in reverse that when in a forward gear! Also, when pulling someone, I would always make them hook to their own car/truck.
When pulling a vehicle out of being stuck, why would you NOT want to use low range?
4L is easier on the torque converter and transmission, slow easy movement of the tow vehicle taking up slack, and if the tires spin, at least they will spin slowly.
I've pulled out skid steers, small dump trucks, 10 ton hayracks. Low range also gives you plenty of reserve power to keep up the momentum if you hit a softer spot on the way out.
Ok to keep it simple try it in High and if that doesn't work shift to low.
Only time I've ever needed low was in my old Bronco II down in the center median in Wyoming. Broke loose the tires when in High so down to low.
You can get as many opinions and ideas as there are people that read and answer. In the end do what makes works and makes you happy. That's what i do.
As with mud, sand, and other sticky places a lot depends on driver of stuck rig. If they can understand AND help with their throttle should be EZ. If they can't might be better to have pros do it. Worst on ranch, 5 4x4s 2 tow trucks strung out 1/2 mile. Finally cranked up old D6 working with tow rig leapfrogged em out. Personal best 3 4x4s, one 4x tractor and it don't count if no water on floor. Cows enjoyed watching and didn't mind hay spread around mud bog next to lake that rainy afternoon. Recently found RAM 4x4 in mud on other side of large creek and NO place to hook chain. WTHail is short version.
Last edited by Martin Seebach; 12-20-2016 at 02:48 AM. Reason: Sucked greatly was overkill.
bryanmartin
12-16-2018 11:30 PM
Bt-99
Toy Hauler Towing; Fifth Wheel & Bumper Pull
13
02-26-2017 06:22 AM
rcnease
08-19-2013 10:52 PM
