Pulling someone out of snow question
on
Depends on the job. If you just trying to move a car that is stuck on a snow covered street because of poor traction then a fullsize 4x4 truck will move it pretty easily in 4x4 high, but if that same car went off the road at speed and is now high and dry up on a snow bank then it's gonna take a lot more effort to move it. In that case you want 4-low and even then it will take a few good jerks to pull the car out unless the tow vehicle is on completely clear pavement.
Received 6,680 Likes
on
http://www.proformance.com.au/single...OR-UPSIDE-DOWN
on
In general, I understand the ring and pinion issue. At least on the Titan that I currently drive the front differential housing is known to be rather weak and will break under stress. There is a video on Youtube of a guy in a Titan making other folks look bad on the sand dunes. He gets a little too c0cky and goes too far by driving up the sand dune in reverse. Boom! Differential parts are left all over the dune.
Given that the Superduty is a solid front axle I would expect the differential housing itself to be more reliable than one on an independent suspension front axle. Since the Superduty isn't a half ton truck I would also expect the front ring and pinion gears to be able to handle more stress.
Anyhow, it's good to know I still need to be careful about using reverse when in 4x4 mode.
If you can have the vehicle being extracted, applying enough power to turn the wheels, but NOT spin, it is easier to walk it out in snow. Spinning the wheels just settles it further down into the snow, and creates more drag.
If you have to extract the stuck vehicle by pulling them uphill (commonly they drove down into a ditch), and they are usually now sitting in their own wheel ruts from trying to back out on their own, sometimes it can help if you can move them forward (further downhill) a foot or two, so you have some momentum pulling them out, before their wheels drop in the ruts again. It is always helpful to begin by digging out the snow in front and behind all four wheels of the stuck vehicle, so you can get them moving initially, then KEEP moving. If the underside of the stuck vehicle is hung up on heavy/wet snow, dig out as much of that as you can. It can cause damage to linkages/exhaust parts/wiring when being pulled out.
One of the things you guys did not say is when pulling you want to pull from your rear going forward like driving down the road.
The reason for this is the ring & pinion are stronger going forward then backing up. But sometimes you have to do it backwards just go easy.
Dave ----
Dave ----
pcurtice
19
01-13-2015 07:21 PM
