Pulling someone out of snow question
Old 12-11-2016, 07:05 AM
Bt-99's Avatar
Bt-99
Bt-99 is offline
Is it ok to pull someone out of snow in 4wd high or do i have to be in 4wd low. How do you guys do it?
Old 12-11-2016, 07:13 AM
senix's Avatar
senix
senix is offline
Received 1,526 Likes on 1,089 Posts
4 hi is fine.
If really suck I would use 4 lo as you don't have to work the throttle as much.
These newer cars I would really be careful since they don't have too good of pulling points.
Old 12-11-2016, 07:44 AM
Desert Don's Avatar
Desert Don
Desert Don is online now
Received 4,768 Likes on 1,688 Posts
And pull using a FORWARD gear with your rig........the ring and pinion are much weaker in reverse that when in a forward gear! Also, when pulling someone, I would always make them hook to their own car/truck.
Old 12-11-2016, 04:58 PM
EDC8008's Avatar
EDC8008
EDC8008 is offline
2nd gear is best.
Old 12-15-2016, 11:29 AM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
High is fine. Lowrange is for climbing and pulling hard. Just depends on how stuck they are and how much traction you have.
Old 12-15-2016, 04:24 PM
ExcursionPSD's Avatar
ExcursionPSD
ExcursionPSD is offline
When pulling a vehicle out of being stuck, why would you NOT want to use low range?
4L is easier on the torque converter and transmission, slow easy movement of the tow vehicle taking up slack, and if the tires spin, at least they will spin slowly.
I've pulled out skid steers, small dump trucks, 10 ton hayracks. Low range also gives you plenty of reserve power to keep up the momentum if you hit a softer spot on the way out.
Old 12-16-2016, 11:35 AM
EDC8008's Avatar
EDC8008
EDC8008 is offline
Ok to keep it simple try it in High and if that doesn't work shift to low.
Only time I've ever needed low was in my old Bronco II down in the center median in Wyoming. Broke loose the tires when in High so down to low.
You can get as many opinions and ideas as there are people that read and answer. In the end do what makes works and makes you happy. That's what i do.
Old 12-16-2016, 05:50 PM
meborder's Avatar
meborder
meborder is offline
In a newer vehicle with electronic throttle control, they typically use a different throttle strategy which is much less sensitive.
This can be a real help on the slick stuff since it makes it harder to break the tires loose.
Old 12-20-2016, 02:44 AM
Martin Seebach's Avatar
Martin Seebach
Martin Seebach is offline
As with mud, sand, and other sticky places a lot depends on driver of stuck rig. If they can understand AND help with their throttle should be EZ. If they can't might be better to have pros do it. Worst on ranch, 5 4x4s 2 tow trucks strung out 1/2 mile. Finally cranked up old D6 working with tow rig leapfrogged em out. Personal best 3 4x4s, one 4x tractor and it don't count if no water on floor. Cows enjoyed watching and didn't mind hay spread around mud bog next to lake that rainy afternoon. Recently found RAM 4x4 in mud on other side of large creek and NO place to hook chain. WTHail is short version.
Last edited by Martin Seebach; 12-20-2016 at 02:48 AM. Reason: Sucked greatly was overkill.
bryanmartin
12-16-2018 11:30 PM
Bt-99
Toy Hauler Towing; Fifth Wheel & Bumper Pull
13
02-26-2017 06:22 AM
Bt-99
2015 - 2020 F150
37
12-20-2016 11:30 AM
rcnease
08-19-2013 10:52 PM
DieselVol
1999 to 2016 Super Duty
28
06-18-2012 10:43 PM
Quick Reply: Pulling someone out of snow question
