4 tire towing
Old Dec 20, 2016 | 09:33 AM
Badger Mike's Avatar
Badger Mike
4 tire towing
Can I tow my F250 diesel 4x4 four wheels down behind my RV? If so, is there anything specifically I need to do in order to not damage the truck?
Old Dec 20, 2016 | 09:42 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Brakes.??? from MH to truck.
most states anything being towed over 3,000 pounds needs remote controlled brakes. with emergency breakaway system
Old Dec 20, 2016 | 09:47 AM
senix's Avatar
senix
check ford's towing guide to see if you can tow your truck with wheels down.
Old Dec 20, 2016 | 10:54 AM
wrvond's Avatar
wrvond
Only with manual shift transfer case vehicles, not Electronic Shift-On-the-Fly or 4x2 vehicles.
Transmission in neutral, manual transfer case shifted into neutral.
Old Dec 20, 2016 | 04:54 PM
Desert Don's Avatar
Desert Don
If you have the electronic shift 4X4 system, one could tow it by dropping the rear drive shaft, and make sure the front hubs are in the "auto" position. PITA.....for sure!! If it has the manual 4X4 stick selector, shift it to N, transmission to N, hubs to "Free" or "Unlock".
Good luck!
Old Dec 20, 2016 | 05:03 PM
RV_Tech's Avatar
RV_Tech
What they all said. Otherwise don't do it. Historically only the Fords with manual transfer case are true four wheel down tows. I think the owner's manual should cover this and, as Chuck said, supplemental braking system is necessary.
Steve
Old Dec 21, 2016 | 06:46 PM
Just Strokin's Avatar
Just Strokin
From the 2015 Owner's Manual, would assume similar in the 2013 manual.
Two-wheel Drive Vehicles and Four-wheel Drive Vehicles Equipped with an Electronic-shift Transfer Case
Do not tow your vehicle with any wheels on the ground, as vehicle or transmission damage may occur. It is recommended to tow your vehicle with all four (4) wheel off the ground, such as when using a car-hauling trailer. Otherwise, you cannot tow your vehicle.
Four-wheel Drive Vehicles Equipped with a Manual-shift Transfer Case
1. Put the transmission in position N.
2. Put the transfer case in position N.
3. Put the hub locks in the FREE position.
Always make sure that both hub locks are set to the same position.
bamacommander
2009 - 2014 F150
Oct 8, 2023 08:06 PM
oldboots1950
41
Sep 22, 2017 07:44 PM
rrthor
Oct 19, 2016 05:30 AM
v10kenj
2009 - 2014 F150
Oct 9, 2013 10:26 PM
Psyclopse
Jan 27, 2012 09:17 PM
