2017-2019 Super Duty FORScan Spreadsheet
#5746
Guys I need some help. I got Forscan successfully going and was able to change a few things (secure idle, trailer module activiation, etc.) But when I try to add the DPF soot % to my screen the instructions say I need to access the ICP which I think is the Instrument Control Panel. I do not see that as an option in my Forscan modules list. I see APIM, BdyCM, PCM, etc. But I do not see ICP. Is it because of the adapter I'm using? Or is something else wrong?
Here's the one I bought:
#5747
https://www.amazon.com/dp/B09VXQQY3K...t_details&th=1
OBDLink EX FORScan OBD2 Adapter for Ford https://a.co/d/0MLctYF
ZooDad
#5748
@ZooDad I recently upgraded from the SYNC 4.2" screen to SYNC3 that was updated to 3.4 in my 2019 F250 XLT. I finally got the zoom working on my backup camera, the white curved lines work as well as the straight yellow and red lines. What is not showing up is my truck off to the right with the 4 reverse sensor zones. I changed APIM 7D0-02-01 to 5553-0103-40C6, that got my zoom working, but no truck icon with reverse sensor zones. Any help is appreciated!
#5749
sending you a PM
ZooDad
#5750
#5751
On an all day trip of 400-500 miles it will cover the full range.
The following users liked this post:
#5752
Wondering if anyone can help me- I recently purchased a 2018 F350 Lariat Powerstroke. The previous owner used forscan to make some changes. One of the changes he made was Line 81 on the spreadsheet, disable traction control. He didnt save any of the original values.
And I would like to put it back to stock considering all this feature does is disable the switch. The full traction control is on all the time with no way to turn it off. If anyone has the original value so I can put it back to stock I would greatly appreciate it.
Thanks
Thanks
#5753
Thanks
Thanks
#5755
As stated above. Get the original AsBuilt from the MotorCraft web site.
copy the AsBuilt data into excel so you can read it. AB files don’t associate to a windows program.
change the data on line 81 back to factory with ForScan. No IDS or FDRS needed.
ZooDad
ZooDad
#5756
#5757
The following 2 users liked this post by 4wd6.7L:
#5758
The only thing different about the truck is that I took the factory 4.3" screen/Sync module out and replaced it with an aftermarket JVC radio and Maestro module. All of that is working perfectly, by the way. Steering wheel buttons even work great. But does the loss of the little Sync module behind the dash have anything at all to do with ForScan not being able to "see" the IPC module anymore??
I'm trying to diagnose why my interior courtesy lights no longer come on when I open the doors. The lights work on the individual buttons. The main button is "on" to allow them to come on with a door open, but they do not. I want to check the IPC module to see if there are any settings that I need to change, but ForScan won't view the IPC anymore.
#5760
Received 6,975 Likes
on
