2017-2019 Super Duty FORScan Spreadsheet
#5761
Bob
#5764
Here are the options shown for my 2019. The bottom line is how mine was configured from the factory. I didn't make any change when installing the two Odyssey batteries, left it as is.
![](https://cimg7.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/561x630/20210814_183635_ae88db04d8d42557dae3923a6e7277f35719291d.jpg)
#5765
2019 F250 XLT 6.2 Gas. For those that have added the Ford remote start (lock/unlock/lock) and enabled everything in Forscan, do your taillights come on when you remote start it? My cab lights, mirror lights, front running lights all do, but not my taillights. I remember having to go into plain mode just to get the current lights working with remote start, thinking maybe I missed something. Thanks, Jon
#5766
The following users liked this post:
#5767
Thank you, but apparently I am dumb, or my bulbs are just really dim.......I hit remote start today, went out to the back of the truck and the taillights were on. So it appears its all working properly. I remote start from about 200 yards at work and it works great but I cant tell if its on because 1) its so quiet and 2) its daytime, so seeing any lights is hard. On my 17 F150 with a Borla and Diode Dynamic taillight bulbs, I had a visual and audio proof from that same distance. Thank you for clarification!
#5768
Thank you, but apparently I am dumb, or my bulbs are just really dim.......I hit remote start today, went out to the back of the truck and the taillights were on. So it appears it’s all working properly. I remote start from about 200 yards at work and it works great but I cant tell if its on because 1) its so quiet and 2) its daytime, so seeing any lights is hard. On my 17 F150 with a Borla and Diode Dynamic taillight bulbs, I had a visual and audio proof from that same distance. Thank you for clarification!
from what I researched, it seemed like all one would need is a new antenna/transmitter as I think the factory remote start fobs work off a different frequency, but at the time I did mine I couldn’t find any posts on the forum where someone did it and confirmed for sure, so I went with the tried and true add-on module.
#5769
#5771
#5772
What I had to do when adding the door keypad on my 2019 was check on the sticker behind the BCM (fuse box in passenger kick panel). Hopefully that trick still works for the newer models!
#5774
#5775
@capt caper
The link to the tire size calculator is in post 1 of this thread.
Tire Size Calculator v5
ZooDad
ZooDad
