2017-2019 Super Duty FORScan Spreadsheet
#5702
#5703
#5704
#5705
#5706
#5707
Does anyone happen to know if there’s a way to disable the automatic high beams from turning off when I go below 25mph? I live a couple miles back a hilly county road that’s 25mph with lots of deer and elk, so they’re constantly flicking off and I just want them to stay on unless there’s a car coming the other way.
#5708
#5709
#5710
Yeah, right now I just flick the high beams back on. But I do think the functionality works well overall and I like having auto on, I’d just like to have the high beams stay on at lower speeds is all. Nothing I can think of should require them to turn off for any reason other than oncoming traffic and since it’s speed based I was hoping there might be a way to adjust that.
#5711
And it makes sense, at 20mph you low beams will allow you to see a few hundred feet away and give you plenty of time to stop, no need for high beams at those lower speeds. Looking for hiding deer is a pretty good reason though.
#5712
My wife's new Yukon doesnt turn off based on speed. Coming into an RV park or through a residential neighborhood I am bright-lighting every window and person standing in their yard. It drives me insane, I much prefer my Fords method. Maybe they should lower the limit, but definitely keep the low speed shut off.
#5713
Can FORScan add back the outside temp to the center dash console, it used to be right by the compass heading? During some update Ford did, (bad APIM replacement) I lost the outside temp in the center dash, so now it's only on the Sync 3 when not connected to my iPhone (Car Play). Has anyone else had this issue?
Thanks in advance
Thanks in advance
#5714
Thanks in advance
Thanks in advance
#5715
Thanks in advance
Thanks in advance
ZooDad
