2017-2019 Super Duty FORScan Spreadsheet
#5641
#5642
TIA
#5643
If the box for "auto-regen" is checked then when the criteria are met for a regen to occur, 800km since last or filter is at 100%, then the truck will automatically initiate the regen process.
If the box is unchecked then the the truck will not start the process and will display a warning message that says a regeneration needs to occur. At this point, if you are going to be on a long enough drive for a regen to complete you can simply put a check back in the box and the truck will go into regen. If you are on a short drive and know it won't complete then you have the option to either wait until you are on a long enough drive in the near future or initiate an operator commanded regen while parked.
I am taking a couple assumptions on how you have configured your pickup with Forscan but in general that is what happens with my 2021 F250 PSD.
#5644
#5645
I just did this last week.
90% of the time it would go to regen 2 miles from my house.
Just today I’m pulling my 5ver to the camp ground and 3 miles to go it wants to regen. But now I have the box unchecked.
I can’t believe I have to do this with forscan on my 17 platinum. Why isn’t this just there from the factory. There’s even a spot on the screen for the icon.
#5646
I believe it is this, based on what it says in the spreadsheet:
"Lincoln Style (doesn't unfold/fold with unlock/lock on fob...requires opening/closing door)."
#5647
Hello Guys!
I have been making some changes to my truck now that warranty is up. Some for convince and some for weight savings!
Loving the options with FORScan but I have run in to a couple snags,
- Trying to get the power ports to stay on for 4 hours (726-39-01 Change 1194 to 3870) Did not seam to work (We are talking about the 12v ports and not the 120v right?)
- The exterior marker lights no longer flash when locking the doors and the interior lights stay on for a long time (So long I haven't waited around to see when they turn off, over 5 minuets) I have disabled the dings on the door open and changed the radio time out to 60 min. Thoes are the only ones I think may be related.
Has anyone else had these problems?
Any advice?
Thanks!
Any advice?
Thanks!
#5648
Hello Guys!
https://ford.oemdtc.com/2743/timed-1...d-f-super-duty
#5651
screwed up my folding mirrors messing around with the Module Configuration, not "as built," toggling the different autofold options on and off. I have all the auto fold stuff turn off and power folding back on, but cannot get the mirrors to fold by the button on the drivers door. thoughts?
#5652
ZooDad
#5653
Anyone disable the BLIS and cross traffic alerts in forscan? Installing a flatbed on my 2018 and would like to disable both features since I won’t have the taillights anymore. You can disable them using the menu on the dash, but a little warning light comes on showing it’s been turned off. Was curious if there was a way to disable both with forscan to get rid of the little light. Thanks
#5654
Purchased a Windows Laptop yesterday (MAC/iOS household) and downloaded Forscan and registered on the forum. Just waiting for the adapter to arrive.
I have downloaded my as built config file from Ford.
Things I want to change:
- Enable Bambi Mode
- Disable double honk
- Adjust massage seat time (make it longer)
One thing I can't seem to find is how to extend how long the running boards are deployed. So tired of closing the front door and the boards retracting before I can get the rear open to get groceries or whatever.
Any and all help is greatly appreciated.
Thanks
- Enable Bambi Mode
Thanks
#5655
- Enable Bambi Mode
Thanks
- Enable Bambi Mode
Thanks
Best of luck to you!!!!
