2017-2019 Super Duty FORScan Spreadsheet
#5731
Yeah I figured it out a week ago. I thought I broke them since they stopped folding altogether, but once I reset the door modules back to AsBuilt and then reprogrammed to Lincoln Fold, they started working properly.
Now if I can just find that code for the Continental splash screen I had in my 18 F-150, that will make my day.
The following users liked this post:
#5732
#5734
RE Auto Engine Shutdown Disable w/ 6.7 & push button start on 2019 F250
Setting the 726-22-01 key position to xxxx xxx0 xxxx OR xxxx xxx1 xxxx seems to make no difference to my truck. Regardless of the setting, the truck will shut itself off after idling 30 minutes.
I know you can uncheck the the "auto engine off" option in the instrument panel but you have to do this every single time you start the truck and I hate it.
Would the SEIC high idle mod prevent auto engine off without having to uncheck the box in the instrument panel every startup?
#5735
Try (IPC) 720-01-01 x?xx xxxx xx— Subtract 8 from current value
ZooDad
#5736
#5737
#5740
35" tire calibration code
KubotaOrange76...I have a question for the 37's calibration changes. I changed my tire size in the Body control module (not as-built) to the biggest Ford allows for the Super Duty. It is about a 35" in size. I run Toyo RT's 37". My speed difference at highway speed is about 4-5 mph. This weekend I was messing around with Forscan and changed my as-built to the new code you posted that shouldn't throw a CEL. Well I changed it and it threw a CEL. Sorry...now my question is did you leave you tire size to stock size and just change the code to 0AAE in the as-built file?
#5742
Because my trailer back up camera gets its power from the clearance light circuit I'd like my running lights to come on with the DRL while I'm driving. Would this Forscan change make this happen? Or does it only illuminate the park lights? Right now I turn the headlights on every time I pull the trailer but often forget to turn them off when I stop.
<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}--> Parking lamps on with low beams for DRL BCM 726-26-02 x0xx xxxx xxxx x1xx xxxx xxxx Enables parking lamps while headlights are on low beam when in DRL (daytime running lights).
Thanks!
Thanks!
#5743
I am looking for some help here. I converted my 2017 f350 standard cab from no sync to sync 3. I have it updated to 3.4 and everything seems to work okay except for the following.
The radio plays through both speakers but the bluetooth and usb media only play through the left speaker. I am guessing I need to program one more thing to fix this. My truck only had the 3.5mm jack previously. no bt or usb.
Any ideas?
Any ideas?
#5744
#5745
If I try to adjust it to the right it just goes silent.
