Sponsored by: Real Truck
Surging when doing silent down hill
Old Oct 23, 2016 | 08:11 PM
ugh3012's Avatar
ugh3012
My 2001 F250 with 5.4 gasser surges when it rolls downhill when using the cruise control. It does not do that when it is going up hill or on flat level highway. Any idea why it does that? This is only when I use cruise control.
Old Oct 24, 2016 | 03:29 AM
seville009's Avatar
seville009
"Surges" as in accelerating and picking up speed? If not, maybe it's downshifting (hence the high revs) to slow your speed down to the desired level. I don't think I've ever had cruise control on going downhill, so I can't tell you if mine does that. Just guessing.....
Old Oct 24, 2016 | 05:00 AM
Sam I Am's Avatar
Sam I Am
Try disconnecting the negative battery terminal for an hour then reconnect it and see how it acts. The cruise on my V10 truck was acting weird and this "fixed" it.
I had a 4.6 truck that would surge and run bad, that one had a broken TPS. It was physically broken, the lower range contacts had become so worn they fell off.
Old Oct 24, 2016 | 06:19 AM
ugh3012's Avatar
ugh3012
I will try disconnect the battery to reset the computer. The hill was very small. It was not the big one where the speeds will pick up from gravity. Truck was not shifting at all when surging was happening.
RubyRed 4.30s
Oct 7, 2018 09:14 AM
murphylaw80
Mar 31, 2009 09:11 AM
Aussie Jones
Jul 24, 2008 10:16 PM
booker250
Nov 26, 2005 09:19 PM
Jalene5
1997 - 2003 F150
Apr 1, 2002 06:39 PM
