Sponsored by: Real Truck
Cruise control surge?
Old Jul 23, 2008 | 10:01 PM
Aussie Jones's Avatar
Aussie Jones
G,day everyone.
Now that FTE has helped me sort out my oil leaks, p/steer, and other mods...I am looking for even more help!
My cruise control has a pronounced surge if set between 108-111 km/h (approx 67-70 mph), a bit faster, or slower, or any other speed it all works fine. (most of our legal speed limits are 110kmh)
It's done this since new, and the stealerships were'nt interested in fixing it.
I know its a small thing, but can be annoying...any help is appreciated as always
Old Jul 24, 2008 | 06:52 AM
F350-6's Avatar
F350-6
What RPM's are you running at this speed? Does the problem happen on flat ground or on hills? Towing your trailer or empty?
That speed should put you in the proper rpm range for where you want to be with the cruise. Maybe your problem is when pulling a trailer and you need to bump up the rpm's a little to get to a better spot on the power curve.
Old Jul 24, 2008 | 08:36 AM
285exp's Avatar
285exp
Mine (2001 F250 V10 CC) does the same thing, right at 70 mph. 2 mph either way it's fine. I handle it the high tech way; I don't set the cruise control for 70.
Old Jul 24, 2008 | 12:49 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
This was a known issue for the 2001's, way back when.
Mine did it to me once. Too much torque, and the computer is set to apply too much pedal pressure at the wrong time.
I think there was a recalibration available for it, but now it'll cost you money to get it done, if you can even find anyone who knows what you're talking about.
Don't do 70
Old Jul 24, 2008 | 09:58 PM
Aussie Jones
Thanks Krewat,
Its a bit of a worry when enthusiasts know more than the stealerships, all I need to do now is find one that may know how to reflash the computor.
"Dont do 70".....have you seen how long and boring some of our country roads are? The problem is going as slow as 70
Old Jul 24, 2008 | 10:13 PM
krewat's Avatar
krewat
I'm not sure there IS a reflash for the issue - I've heard there was a fix, not sure what it was.
Old Jul 24, 2008 | 10:16 PM
krewat's Avatar
krewat
tiopet
Feb 26, 2020 06:50 PM
IsaacJR75
Apr 8, 2016 07:45 AM
HotrodEnvi
Mar 21, 2016 10:07 PM
norm805
Mar 28, 2014 07:03 AM
Ranger256
Escape & Escape Hybrid
Dec 30, 2005 01:41 PM
