E3TZ-18476-E Does It Fit?
Old Oct 5, 2016 | 04:59 PM
1972RedNeck's Avatar
1972RedNeck
I need a heater core for our '70 highboy. The part number is something like C7TZ 18476 A but subs to E3TZ 18476 E according to a few threads I ran across. I googled the part number and Dennis Carpenter came up - but they list it as an '80 - '86
Heater Core With Std Heater | Dennis Carpenter Ford Restoration Parts
Does the picture look to be the right one?
What gives here? I would like to order a NOS copper heater core instead of new cheapo aluminum Chinese knockoff but will it fit?
Old Oct 5, 2016 | 05:27 PM
JEFFFAFA's Avatar
JEFFFAFA
C7TZ18476A was the correct number for a heater core for 67/72 F100/750 "without" factory A/C. Then C7TZ18476A was replaced by E3TZ18476B. This was replaced by E3TZ18476E.
Looking at the 1983 model year Bullnose to get an example, E3TZ18476E is not listed for Bullnoses.
1983(Bullnoses)
E3TZ18476F........with hi output heater.
E3TZ18476G........with Factory A/C or hi/low vent system.
E3TZ18476H........with standard heater.
So yes, the E3TZ18476E should fit a Bumpside without factory A/C.
Old Oct 5, 2016 | 08:45 PM
1972RedNeck
1983(Bullnoses)
Well, I'll give 'er a go and report back!
Old Oct 6, 2016 | 12:16 AM
Ford_Six's Avatar
Ford_Six
I know some people like running Ford parts, but I've been running Napa and Oreillys heater cores for years. My truck got a nice new Oreillys core when the diesel went in, and it was still holding strong four years and 40k+ later when I tore it back down.
Old Oct 6, 2016 | 01:43 PM
1972RedNeck
I'm not too opposed to an aluminum one but if the one from DC fits, it's about the same price and should last another 35 years.
Old Oct 7, 2016 | 12:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Looking at the 1983 model year Bullnose to get an example, E3TZ18476E is not listed for Bullnoses. 1983(Bullnoses)
Uh huh...I hate to be the bearer of bad news.
You know of course that the E3TZ-E heater core was not used in any 1980 and later trucks, but are you aware that it's smaller than the original?
E3TZ-18476-E is also listed for 1973/79 F100/350 with the economy heater, but...
Take a look see in the 10/88 microfiche final edition of the 1973/79 truck catalog under 18476 for the 18658 seal you had to get along with this heater core...so it would fit correctly.
I remember this jazz from years ago, and so...when members ask for a heater core for these trucks, I do not mention the E3TZ-E core because no one has EODZ-18658-A
Old Oct 7, 2016 | 01:22 PM
JEFFFAFA's Avatar
JEFFFAFA
Maybe, maybe not. It is true that listed for 73/77 F500 it shows C7TZ18476A replaced by one each E3TZ18476B "and" E3TZ18658A. But does not state the difference or the reason why. If you notice the listings above this for F and E series trucks it also mentions which part number 18658 seal applies. As a matter of fact, this is the only place that which 18658 seal applies to a truck is listed. If you go to section 180,page 17 you will see Ford skipped right over listing any 18658's. When I went to my OSI micro-fische slide yesterday it mentioned the E3TZ-B and then E3TZ-E part number replacements but no other part numbers needed.
Lastly, I know this is not Ford, but the aftermarket world lists both a 1972 Bump and 1974 Dent heater core this way:
Product SpecsPart Number 94572Core Material AluminumHeight; Dec. 6.00Height; Frac 6Height; Met 152.00Width; Dec 6.00Width; Frac 6Width; Met 152.00Depth; Dec 2.00Depth; Frac 2Depth; Met 51.00Dimensions 6 x 6 x 2Inlet; Dec 0.63Inlet; Frac 5/8Inlet; Met 16.00Outlet; Dec 0.63Outlet; Frac 5/8Outlet; Met 16.00Tube Material AluminumTank Material AluminumUniversal/Specific Specific OE Cross Reference OE ManufacturerOE NumberFORDC5TZ18476BC6TE18476CC6TZ18476CC7TZ18476A D3TZ18476CE3TZ18476E
Old Oct 7, 2016 | 02:11 PM
NumberDummy
Text, Section 180, page 9 of the 10/88 microfiche final edition of the 1973/79 100/500 truck catalog sez:
E3TZ-18476-E .. Heater Core - Use with EODZ-18658-A (seal)
This seal was required (use with) for the E3TZ-E heater core because it was a different shape than the C5TZ-18476-B - C7TZ-18476-A - D3TZ-18476-C originals.
Speaking from experience, since I recall what occurred at the back parts counter, if people buy this E3TZ-E heater core, they're gonna be p!ssed when it does not fit correctly!
E3TZ-18476-E (replaced C5TZ-18476-B - C7TZ-18476-A - D3TZ-18476-C - E3TZ-18476-B) .. Heater Core:
C5TZ-18476-B = 1965/66 F100/250 // C7TZ-18476-A = 1967/72 F100/750 & 1973/79 F500/880 // D3TZ-18476-C = 1973/79 F100/350 with economy heater.
Norton72
Sep 5, 2019 02:40 PM
njdevil77
Mar 28, 2018 08:16 PM
waggondragger6213
Nov 1, 2009 04:11 PM
dennisb56
Feb 18, 2008 11:13 AM
don_79f250
Dec 13, 2004 07:32 PM
