Newest Problem
Old Sep 19, 2016 | 08:51 PM
  #121
WhatsAChevy?'s Avatar
WhatsAChevy?
Originally Posted by hharris8
I already replaced the pigtail which came with shrink tubing and crimps. Since I had a crimping tool and the manufacturer wanted me to use crimps, I did not use solder there.I did add dielectric grease before putting on the shrink tubing though.
OK....cool. Now that is done. What did you come up with matching the alternator at the parts store? any luck?
Old Sep 19, 2016 | 09:11 PM
  #122
hharris8's Avatar
hharris8
Wasn't able to get the the AP store today. I will try tomorrow. Why have I stopped getting email notifications? I have not changed any settings.
Old Sep 19, 2016 | 09:25 PM
  #123
WhatsAChevy?
email notifications do not matter at this point given your trucks problems...Focus ! Are You able to log in on a laptop or desktop? Obviously you are able to on your phone.
Old Sep 19, 2016 | 09:47 PM
  #124
hharris8's Avatar
hharris8
Yes, I can. I did not know anyone had been posting today until I came to the forum and saw this thread was unread.
Old Sep 19, 2016 | 09:55 PM
  #125
ctubutis's Avatar
ctubutis
This happens sometimes; IB (owner of this place as well as ~100 other such forums) sends a LOT of e-mail, and some e-mail providers, some ISPs, throttle them. They will most likely show up at some point, though.
Old Sep 19, 2016 | 09:58 PM
  #126
hharris8's Avatar
hharris8
Great. Thanks. Till then I will keep checking here.
Old Sep 19, 2016 | 10:25 PM
  #127
WhatsAChevy?
Glad You verse Millennium Speak Chris !
Old Sep 19, 2016 | 10:33 PM
  #128
WhatsAChevy?
In all my years, I never thought that explaining simple mechanics and electrical systems would be so hard to such a resistant generation. -{Quote} :
Old Sep 19, 2016 | 10:36 PM
  #129
ctubutis's Avatar
ctubutis
Millenium Speak? Is that an insult? Or a compliment? Or, what? I consider myself Gen X.
Old Sep 21, 2016 | 11:05 AM
  #130
hharris8's Avatar
hharris8
Millennium speak is a compliment. My generation speaks the best . I replaced the alternator and lubed the plugs and got everything attached. (I had to change the pulleys because the alternator I had was pieced together. The alternator I got had a serpentine belt pulley, but it was a easy change out.) Is there anything else I need to do before putting the battery cable back on and checking for heat?
The alternator I got is a 75 amp. There was an 80 for $40 more and it would not arrive for two days, but the only thing electric in this truck is the rear window and a cb. The radio does not even work and there are currently no speakers in the doors or anywhere else in the truck (though I may try and fix the radio and speakers in the future).
Oh, and I forgot to pick up some fusible link wire. Can I still try it without it?
Old Sep 22, 2016 | 09:29 AM
  #131
hharris8's Avatar
hharris8
Wow, speech statements must be a touchy subject here. I scared everyone off. If it helps the 60's, 70's, and 80's had the best trucks.
I am getting emails again by the way.
Old Sep 22, 2016 | 10:03 AM
  #132
ctubutis's Avatar
ctubutis
I just didn't want to go search through 9 pages to figure out which fusible link(s) you're talking about, I forget this kind of stuff overnight (or sooner). I remember you have the alternator with the fire plug that was melting wires and which didn't seem to be putting out the correct voltage, you replaced the fire plug pigtail as well as the alternator but I don't remember anything about any fusible links, is one or more of them blown? Did it/they burn up? In any event, best course of action is to ensure everything is in the condition needed to operate as designed.
Old Sep 22, 2016 | 10:12 AM
  #133
hharris8's Avatar
hharris8
Post 56 last pic. It is the orange fusible link on the black wire. They did not burn and it does not pull apart. It looks exactly like in the pic. If I plug up everything and the link is bad will it hurt anything?
Old Sep 22, 2016 | 10:16 AM
  #134
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Fully charge the battery *before* you start the truck.
If it is open (but continuity says it is not) then the alternator will overheat again, trying to push current to a battery it can't reach.
Old Sep 22, 2016 | 10:19 AM
  #135
hharris8's Avatar
hharris8
If I remember correctly you said to check for continuity I need to put the test points on the wire on the solenoid and the other on the alternator body and then switch them correct?
