Newest Problem
Old Sep 12, 2016 | 06:39 PM
  #76
ctubutis's Avatar
ctubutis
The smaller D-shaped connector goes to the voltage regulator, this isn't where the problem lies.
The waxy stuff you're scraping out is a water dispersant/sealant/repellent-type of stuff, people generally use dielectric grease for that purpose these days.
Old Sep 12, 2016 | 06:47 PM
  #77
hharris8's Avatar
hharris8
Do you see any problems in the pics that may be causing my issues? I have dielectric grease so I can put some of that upon reassembly.
I have been searching for TSB 96214, but cannot seem to find it. Where should I look?
Old Sep 12, 2016 | 07:29 PM
  #78
ctubutis's Avatar
ctubutis
Jim @ArdWrknTrk has posted the links before, I found some (non-authoritative) stuff searching on:
Ford TSB 96-21-04
maybe that will help?
EDIT: Found this PDF copy of it:
https://www.google.com/url?sa=t&rct=...32479545,d.amc
It's really hard to determine stuff with pictures and I don't see anything jumping out at me (other than stuff needing to be cleaned up at a minimum) and I had totally forgotten about that 2G alternator-fire stuff. And there is always the chance you have more than one problem and this isn't the only thing that's wrong - but begin with what is known to need fixing, one thing at a time.
I'd still be inclined to take the thing in to be tested, it's not putting out the kind of voltage I would expect to be seeing BUT bad connections/burned wiring/etc. can contribute to that, too.
Some guy made a youtube video in which he explains some stuff but it's equally as unclear as anything else.
Also might do some generic searching, e.g.
Ford 2G alternator plug
Old Sep 12, 2016 | 08:31 PM
  #79
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The charge plug crumbling or melting is exactly what causes fires with these 2G alternators.
Please unwrap that thing and replace the pigtail *if* the damage hasn't gone too far.
Wire loom, extra tape, or whatever you have going there may look neat, but it is only exacerbating a *known* overheating problem.
Just the other day there was discussion about derating wire capacity because they were not in 'free air'
Things will heat up.
Wires bundled together will heat each other up.
Taping wires together means air cannot flow around them to carry away the heat.
Putting another sleeve over all that is like wrapping it up in a blanket.
The corrosion in your alternator charge socket is causing resistance, which is turning electricity into heat.
Use some electrical contact cleaner and an old toothbrush to get those blades clean and shiny.
Then put some dielectric silicone in there to inhibit oxidation and displace moisture.
Here's a list of pigtails...
Originally Posted by ArdWrknTrk
Borg-Warner PT-780
Standard Motor Products S-542
Power Plug 4628011
KEM Parts 350-220
Pico 5711
Dorman 85123
Motormite 08622
Motorcraft WPT-119
NAPA VRA 400
Ford OEM kit E5AZ-14305-AA
Old Sep 12, 2016 | 08:58 PM
  #80
hharris8's Avatar
hharris8
Thanks Chris. I could not find that anywhere.
ArdWrkTrk, what is your secret for finding parts? I had been searching for that pigtail for a half hour when you posted to no avail. I will unwrap the wires. The cover is supposed to keep heat out, but I did not think about it keeping it in. The electrical tape is only on the ends to keeps the sleeve put.
Since the two wire connector is falling apart should I replace it as well? What part number is that?
Old Sep 12, 2016 | 09:10 PM
  #81
ctubutis's Avatar
ctubutis
Welcome, Jumpski.
Might check here for your D-shaped thing (follow the link to the ID guide):
https://www.fordparts.com/Products/W...gtailKits.aspx
I have no idea where Jim gets the aftermarket numbers from but this is a 20 yo problem so there's been plenty of time.
Old Sep 12, 2016 | 10:27 PM
  #82
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My 2G harness was replaced twice and when it failed a third time I said #$@&*£×¥ this!!!
Bought a conversion kit from the now defunct RJM, and a 130A Motorcraft 3G from Ebay for $75 delivered.
I have seen a lot of threads about the plugs melting so I cross referenced the part numbers and put them all in one post so people that were reading about the problem would have enough options.
My truck uses the 'ASI' three wire regulator plug. (the white/black stator wire goes to my electric choke)
You could always just cap or cut off the 'S' wire...
Old Sep 13, 2016 | 07:22 AM
  #83
hharris8's Avatar
hharris8
I got the Dorman replacement part and it should arrive Thursday. If it melts again I will probably convert.
Do I just drop by AutoZone to get the alternator tested? Can I do it myself?
Old Sep 13, 2016 | 09:26 AM
  #84
ctubutis's Avatar
ctubutis
You need to remove it from the vehicle and bring it to them, they'll put it on their alternator/starter-motor testing machine and test it.
Old Sep 13, 2016 | 09:50 AM
  #85
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Once you replace the charge pigtail and clean the contacts do the diode test again.
Try it with the leads both ways. i.e. Red on the solenoid end and black on alternator case, then black on the eyelet end and red on the case.
Old Sep 13, 2016 | 09:52 AM
  #86
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Your AutoZone doesn't stock the pigtail????
Maybe I'm just getting too old.
Old Sep 13, 2016 | 04:34 PM
  #87
hharris8's Avatar
hharris8
I have just about given up buying from local auto parts stores during this process. They never seem to carry anything I need (or if they do they do not know about it) and the workers there have absolutely no knowledge of cars nor their parts.
I will try and bring the alternator by there sometime this week though and get it tested.
Old Sep 13, 2016 | 05:20 PM
  #88
FuzzFace2's Avatar
FuzzFace2
Originally Posted by hharris8
No problem. What job requires such demanding hours? I was working on classes all day anyway. I will try and get at that screw from the bottom tomorrow. Any tips on how to pull it?
I drive a pneumatic tank trailer filled with powdered cement. Dispatch gives me the pickup place and the drop off place with the time it needs to be there.
I got to sleep in today till 2am. Did 400 miles yesterday & today. When I am not doing cement they put me on LP gas tank trailer.
Job is 1 reason why I have not worked on my truck lately, just too tired when it’s not too hot.
Can you see what is on the other end of the ground bolt? There may be a nut and them come right off? If not then can you get a grinder in there to grind the head of the bolt off and then push what is left out the other way.
Dave ----
Old Sep 13, 2016 | 05:26 PM
  #89
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If you have a grinder in there you may as well use it to clean up the mounting surface before bolting the strap back on.
I usually put Noalox on things like this and behind the grounding ears of my starter relay.
Old Sep 13, 2016 | 06:39 PM
  #90
hharris8's Avatar
hharris8
You were right, it is a nut. It looks just like the screws holding the solenoid on so I did not think about a nut. I will clean that up. What is Noalox? Something like dielectric grease?
