Newest Problem
Old Sep 19, 2016 | 09:35 AM
  #106
WhatsAChevy?'s Avatar
WhatsAChevy?
A fusible link is essentially a smaller gauge wire spliced into a segment of a larger gauge wire which will burn/break/fail protecting the components that the larger gauge wire feeds/services. Cut the fusible link out and take it with you when matching the alternator. Buy it about 6 inches longer. AP stores carry it in packaged lengths and cut to length from a roll/reel.
Old Sep 19, 2016 | 10:03 AM
  #107
ctubutis's Avatar
ctubutis
Purchase an alternator from the parts store that they say is for your truck, or that at least appears to offer the best chance of working for your installation; you would be safe with the one with the highest amperage capability. The alternator that came with a sedan would be a 1G which is different than your 2G (1st generation, 2nd generation).
I wouldn't give up the old one as a core until the new one was installed and working (at least physically attached and hooked up).
I suggest using solder & heat-shrink tubing if you're going to be replacing wiring components (e.g. fusible links) or doing any other such work.
Old Sep 19, 2016 | 10:08 AM
  #108
ctubutis's Avatar
ctubutis
And also replace that connector pigtail!
Old Sep 19, 2016 | 10:14 AM
  #109
WhatsAChevy?
I agree on soldering & shrink tubing, just wasn't sure of his capability (no offense to hharris8).
Old Sep 19, 2016 | 10:22 AM
  #110
ctubutis's Avatar
ctubutis
That's a good point; harris, do you know how to solder? Heat up the two wires you've interleaved together, let the hot wires melt the solder; it should get "sucked into" the splice, this ensures a good joint. Don't just melt the solder with the siring iron or gun and then apply it to the wires, that creates cold joints that will break apart easily.
When comparing alternators, many of the differences will be the locations of the mounting ears in relation to the electrical connections, the sizes of the mounting holes (and maybe threaded sizes, if any) things of that nature. Compare physical attributes & sizes.
Old Sep 19, 2016 | 10:40 AM
  #111
WhatsAChevy?
I use what used to be referred to as a "Western Union" splice, soldering as Chris stated.
Old Sep 19, 2016 | 10:41 AM
  #112
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The truck has a 2G, he should replace with a 2G.
They are all 65A.
Clocking may differ.
all Windsor engines take 7" C-C pivot mounts.
The charge plug pigtail kits come with adhesive lined butt crimps.
.... it's good enough for Ford, it's okay in this situation.
I am not sure what any of this has to do with hharris8's insistence that this is engine is from a '70's passenger car.
Should I insist that my engine is from a '79 based on the block casting #?
Old Sep 19, 2016 | 11:00 AM
  #113
WhatsAChevy?
They are all 65A.
Very true on all points Ard. The year of the engine itself should have no bearing as long as all of the bolt-on's are reasonably correct for the truck.
Old Sep 19, 2016 | 12:51 PM
  #114
ctubutis's Avatar
ctubutis
Likely he doesn't know what clocking is, and maybe C-C.
The term clocking refers to the case half and how it is orientated (rotated) before before attached to the other half/remainder of the body and basically determines where the electrical connections get orientated.
The term C-C is 'center to center' used for measuring purposes.
Just trying to clarify for readers.
Electrical, there are various techniques & methods, I'm just trying to reinforce that good connections are necessary for reliable use in a hot & dirty underhood environment.
Old Sep 19, 2016 | 01:27 PM
  #115
WhatsAChevy?
I was going to address the clocking issue but again, not sure of the level of expertise here so...Thanks Chris for defining. Kinda why I suggested a direct match-up at the AP store. There is a Motorcraft/AC Delco distributor here locally that I can get parts from at wholesale pricing but I need at bare minimum, a picture to match it (for the clocking & C to C reasons).
Old Sep 19, 2016 | 02:17 PM
  #116
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Once again, Chris I apologize for spouting off without any detailed explanations of the how & why.
The old RJM website used to show the various clocking so you could decide which you had and which of the different orientations you needed.
I had hotlinked those photos into some threads, but their server and those images are long gone now.
I think it best to use the old one to compare.
Surprised that hharris8 did not do this while in the store after it tested bad.
Old Sep 19, 2016 | 02:26 PM
  #117
ctubutis's Avatar
ctubutis
No problem, Jim, I hope it serves as an example of how I'm afraid people just don't understand what you're trying to say sometimes.
Yeah, I thought the same thing... but maybe he had it tested at a local fix-it shop or some place that didn't necessarily have replacements on hand for some reason.
Another possibility comes to mind - some people in today's society (usually "the kids" in my experience) like to do all their shopping online for whatever reason, maybe they want to do some more investigation before spending any money, or maybe they don't trust the offerings or personnel of a local brick & mortar store.
Or maybe there are other reasons, too, that's just what came to mind.
Old Sep 19, 2016 | 03:40 PM
  #118
hharris8's Avatar
hharris8
This is one of those times when you may h
I have to give you kudos though. You are tenacious in attacking so many issues with this truck with due diligence.
Makes it a lot easier when there are people to walk you through it like y'all.
I do know how to solder. The only way I splice wire is by pushing the two wires together where the wires are well in mingled and then twisting. I then solder and put heat shrink tubing over it.
The fusible link on there now is in a semicircle case. It can be seen in one of my pictures. It is orange on the black wire. Does it just have a smaller diameter wire inside it?
I did not get a replacement at the auto store because I wanted to check with y'all first and get any suggestions before buying. (I also was expecting the alternator to test good since I never had battery issues so I did not bring any money).
I will bring it back by the auto store and get a match.
Thanks for clarifying C&C. That is some good info.
Old Sep 19, 2016 | 03:42 PM
  #119
hharris8's Avatar
hharris8
I already replaced the pigtail which came with shrink tubing and crimps. Since I had a crimping tool and the manufacturer wanted me to use crimps, I did not use solder there.I did add dielectric grease before putting on the shrink tubing though.
Old Sep 19, 2016 | 05:33 PM
  #120
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You are fine with crimps and shrink tubing.
The Ford engineers used this method to speed/simplify the repair and eliminate the variable of cold solder joints.
Since there was liability involved, lawyer-speak in the TSB says "inspect any time the charging system is serviced"
I'm sorry, I didn't think about going to the parts store with no money.
btdt.
