Big thanks to RiffRaff and OUO!
Some of you may remember the modification fest I had last winter during Christmas break. If not, you can see the thread by clicking here.
Anyway, I was just about to blast off another Buckzooka round for parts and modifications for this winter after camping season is over and nearly made a $1200 mistake.
I built and purchased my parts list which is below...
Tekonsha P3 - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Tekonsha Wiring Harness - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
YG350 Heater Core Valve - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Curt 5th Wheel Harness - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Air Lift 5000 - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Bilstein 4600 shocks - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Bilstein Stabilizer - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Fuel Bowl Reseal Kit - A complete Fuel Bowl reseal kit for the Ford 7.3L diesel filter canister 1999-2003
Pressure Sensor 90 - Search results for: '13-002'
OEM Fuel Filter - Search results for: '13-021'
OEM Fuel Filter Lid - Search results for: '13-020'
CCV O-Rings - CCV Vent Cover Orings
HPOP Line Drivers Side - HPOP Line - Driver Side Head
HPOP Line Passenger Side - HPOP Line - Passenger Side Head 99.5-03 - Riffraff Diesel Performance
HPOP Tool - HPOP Quick Disconnect Hose Removal Tool for Ford 7.3L 99-03
Loctite 680 - Loctite 680 Coarse Thread Locker .5ML - Riffraff Diesel Performance
2 x HPOP Outlet Fitting - HPOP Outlet Hose Fitting - Non Check Valve - Riffraff Diesel Performance
Fuel Bowl Heater Element - Fuel Bowl Heater Element - Riffraff Diesel Performance
DeeZee Tailgate Assist - Dee Zee Tailgate EZ Down
OUO Traction Bars - OUO Bolt-On Traction Bars w/U-Bolt Flip - Riffraff Diesel Performance
The last item on the list is costing a pretty penny, but I think will save me money in the long run when towing heavy due to wear and tear on the drive line. My truck has axle wrap only sometimes when unloaded, but all the time when I have our travel trailer connected. Anyway, I was just about to purchase the "bolt on kit" by OUO from RiffRaff when I thought maybe I should check to make sure that kit is compatible with the AirLift system because they will be in the same area. Turns out Jared from OUO told me it was not compatible and that I would need the "U-bolt flip kit". After several emails with Clay and Jared trying to figure out exactly what I needed because there appeared to be additional parts required, Clay called me up to answer the questions I had over the phone eliminating any confusion.
We spoke briefly about what I wanted and he assured me that the parts I would need for a clean install would be included in the U-bolt flip kit and it would work with my AirLift system.
This is top notch customer service from both companies that is hard to find nowadays. I have had great experiences with RiffRaff in the past, and will continue to be a customer of his for as long as I own a PowerStorke.
Real world experiences with the PMF bars were sent to me by FTE brothers and I valued that advice/information very much. In the end, the mounting application of the OUO over the PMF bars was one of my major concerns. Also the price between the two bars was very similar after shipping and selecting certain parts.
I am 100% confident I will be happy with the OUO bars and AirLift 5000 systems working in tandem. I plan to take a lot of pictures and post my thoughts on the install process and end result.
You're going to love having traction bars when towing. I just finished towing for a 3,000 mile trip (Yellowstone & Glacier) and the PMF weld on traction bars performed flawlessly. I never know they are there and can apply all the throttle I need to get going from a standstill with no wrap up and vibration. I also run the airlift bags and those are fabulous too which I run at 80psi. FWIW, the Rancho 9000's work good with them. I crank up the valving to max when towing and to min when empty and this seems to work very well with the bags.
SRBF150
25
08-06-2015 09:23 PM
