Can I pull a CCtest on an early "99
Old Aug 17, 2016 | 08:35 PM
tommyl's Avatar
tommyl
I have a early '99 F350. Can I pull a CCT with AE? Right now I don't have a No.1 cylinder grid, 2 thru 8 do not show any response. AE CCT works fine on late '99s.
Old Aug 17, 2016 | 08:41 PM
Pikachu's Avatar
Pikachu
Yes, a CCT should run on an early 99. What are you referring to as a "cylinder grid?"
Old Aug 18, 2016 | 09:23 AM
Walleye Hunter's Avatar
Walleye Hunter
I have run the CCT on my E99 with AE and it seemed to work fine.
Old Aug 18, 2016 | 10:18 AM
tommyl's Avatar
tommyl
I'm referring to the PID. When I bring up 1 thru 8 pid, I have no number 1. 2 thru 8 will display, but there seems to be no activity on any of them.
Old Aug 18, 2016 | 08:43 PM
tommyl's Avatar
tommyl
So what would the most likely cause of not being able to run a CCT, seeing that others are able to?
Old Aug 18, 2016 | 08:49 PM
Pikachu's Avatar
Pikachu
If the test fails to complete, you should get a code. What exactly is happening when you run the test?
Old Aug 18, 2016 | 09:25 PM
Rikster-7700's Avatar
Rikster-7700
You are trying to run the test at idle, correct?
DennisA (IL)
May 12, 2018 09:15 PM
shanksyamaha
Mar 31, 2009 10:40 PM
GrizzlyPiet
Nov 30, 2008 06:55 PM
MESTRKR
Jan 17, 2005 10:11 PM
editdog
Jul 11, 2002 08:37 PM
