Anybody running this?
Old Jun 18, 2018 | 08:50 PM
z31freakify's Avatar
z31freakify
Anybody using this kit? Its not like RR regulated return is it?
https://m.ebay.com/itm/E99-03-7-3L-P...EAAOSw9OFZJyVY
Old Jun 18, 2018 | 09:15 PM
00t444e's Avatar
00t444e
Many people on powerstroke.org run his kit and are happy with it, I would get one but I already have the Riff Raff fuel rail crossover and it works fine. Yes that kit is a regulated return and it eliminates the dead head in the factory fuel system.
https://www.cncfab.us/shop/cnc-sd-7-3brfk/
Old Jun 19, 2018 | 01:58 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
That is the EXACT kit from CNC Fabrication. The location is even the same which is Defiance Ohio. The pictures even include CNC Fabrication at the end.
I know Akcooper9 just installed one of these kits on his truck and maybe his FIL's too.
As for CNC Fabrication, Corey is a stand up guy and will make things right if they go wrong as they sometimes do. I have had personal experience with this and he made every effort to correct the manufacturing defect that he was not aware of until the problem presented itself in my situation.
and
https://www.cncfab.us/contact/
Old Jun 19, 2018 | 02:13 PM
Dan V's Avatar
Dan V
If you look at the Ebay seller id....hucorey
Old Jun 19, 2018 | 02:17 PM
akcooper9's Avatar
akcooper9
Sous is correct, I have the 4 way feed kit on two trucks. Very happy with the results. Smoother idle and very crisp throttle response.
Old Jun 19, 2018 | 02:50 PM
Sous's Avatar
Sous
FTE Emeritus
Missed that, thanks for pointing it out. I was on my way to get another beer, so my priorities were in another place.
Old Jun 19, 2018 | 02:59 PM
akcooper9's Avatar
akcooper9
Retired life....must be nice!
Old Jun 19, 2018 | 03:17 PM
00t444e's Avatar
00t444e
That's his eBay name it's the same guy.
Old Jun 19, 2018 | 05:21 PM
Stewart_H's Avatar
Stewart_H
You guys miss rattlesnakes more than I do!
This is all I saw when I clicked the link...
...ok, to be transparent, I didn't actually see the above pic, my minds eye added the red highlight boxes and arrows.
Stewart
Old Jun 19, 2018 | 07:42 PM
Jo7.3's Avatar
Jo7.3
So for those that have installed this 4 line feed kit, was it a hard install? Seems to me a lot of stuff would have to come off the top of the motor in order to do a clean install? And also, what benefits (if any) have y’all seen besides a smoother idle and crisper throttle. Thanks.
Old Jun 19, 2018 | 07:47 PM
akcooper9's Avatar
akcooper9
I have a T4 setup so my rear lines are different . The front is tight but I did the second install much quicker (like most things)
Old Jun 20, 2018 | 08:31 AM
Dan V's Avatar
Dan V
Well....it's good to see your priorities are in the right order!
Old Jun 20, 2018 | 01:59 PM
guitarpicr's Avatar
guitarpicr
I second that .Mans got to know his limitations .
bigpetie
Jul 11, 2014 02:18 PM
mblack14
Jun 30, 2012 06:15 PM
messeswithtrux
Nov 23, 2007 05:57 AM
mbogosia
May 28, 2007 10:17 AM
eric777
May 8, 2006 05:04 PM
