Oil and Coolant Temp Sensor
Old Aug 1, 2016 | 02:20 PM
  #31
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Originally Posted by hharris8
I look at the Bussman add-a-fuse. How can I tell what side is the load side?
You need to probe the fusebox socket and find the side that *does NOT* have power, with the key in run.
Install the Add-a-fuse with the red wire coming out that side.
Old Aug 1, 2016 | 02:31 PM
  #32
hharris8's Avatar
hharris8
Does the red wire just crimp over the choke wire or is there something else I will need to get with it? Also, would my 86 be a ATM or ATO?
Old Aug 1, 2016 | 02:35 PM
  #33
hharris8's Avatar
hharris8
Would I still use fuse #11 and just plug that fuse into the add a fuse as well or would that overload the circuit?
Old Aug 1, 2016 | 04:06 PM
  #34
Gary Lewis's Avatar
Gary Lewis
As Jim says, it matters a great deal. To find the powered side, pull the fuse and use a volt meter or test light. And an add-a-fuse is a good idea. The choke would probably be fine on a 5 amp fuse.
Old Aug 1, 2016 | 06:03 PM
  #35
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My '87 truck uses ATC/ATO style fuses.
You need to strip ~3/8" of insulation before you slip the wire in and crimp it.
If you install the add-a-fuse backward all the power will flow through the primary fuse first, and then back through your added fuse before entering the choke circuit.
Old Aug 1, 2016 | 08:38 PM
  #36
hharris8's Avatar
hharris8
Just thought I would post for anyone looking. This is the cheapest terminal for sending units I could find online and it has free shipping. https://lmr.com/item/HDW-10884/Musta...-Wire-Terminal
Old Aug 1, 2016 | 08:44 PM
  #37
hharris8's Avatar
hharris8
Is that third wire for a two pronged oil or temp sensor? If it doesn't move the gauge when touching the block and the other ones do then I don't know if thats possible.
Old Aug 1, 2016 | 08:45 PM
  #38
hharris8's Avatar
hharris8
Also whats the difference between a temp sender and sensor and which do I have?
Old Aug 1, 2016 | 10:41 PM
  #39
Gary Lewis's Avatar
Gary Lewis
I don't understand. A temp sender is the same as a sensor, but most are 1-wire units. The terminal connects to a resistor that changes due to oil pressure or coolant temp. High pressure or high temp is 10 ohms to ground and low temp/pressure is 72 ohms.
Old Aug 2, 2016 | 07:40 AM
  #40
hharris8's Avatar
hharris8
OK. Thanks. I was looking at a wiring diagram and one said sensor and the other sender and I was't sure if I didn't understand something.
Old Aug 2, 2016 | 09:57 AM
  #41
ctubutis's Avatar
ctubutis
Gary Gary Gary please be careful here...
There is no real consistency in the aftermarket concerning this stuff and the terminology but here is how I refer to things...
A sending unit (aka sender) is a one-wire device used by the dash gauges.
A sensor is a multi-wire device used by an onboard computer and has nothing to do with the dash gauges.
Rippin6Gears
Jan 17, 2016 10:53 AM
l1011man
Escape & Escape Hybrid
Jan 28, 2013 08:25 PM
pace car
13
Sep 23, 2012 03:50 PM
branden.w
Nov 21, 2009 07:09 PM
