please help me .I need replace the oil pressure sensor and I need some photo of wires and for the cranshaft sensor,I'm not found the original wires where I can buy the plugs???
Hi,please can you help me for replace the wires of oil pressure sender? on my truck 83 351w.I'm not found the original wires I have see 3 wires all in one on the pressure oil sensor, I wish to have the correct wires for the ligth to on instrument ,sorry for my bed english thankyou
Hi DAVE,thanks alot for help ,I found it, I start to replace the wires,needs 2 new wires,where is the oil lamp position on dash instrument controll?By By
Your oil pressure sender only has one wire. It's a white/red wire. The temp gauge sender also only has one wire, and red/white wire.
Sorry,I found one red wires goes to the plug with another one grey,near the oil pressure, and goes to the oil temperature ,and the same red wires goes to the oil pressure are correct? can you send me photo or diagram? thankyou
Hi Dave, yes I have gauges for the oil pressure on dash,and two oil pressure one have red wires, the other have a plug with 2 wires, one grey and one red ,the wires red goes to the same first oil pressure,what can I do for post the photo?regards
pace car - Because you paid to help support FTE, you can directly attach pictures to your posts. When using the Advanced editor, click on the Manage Attachments button to browse to your picture(s).
The plug with 2 wires next to your oil filter is the Oil Pressure "Switch". it gets power from fuse box (fuse 18). When there is oil pressure (engine is running), the switch closes and lets power through it to power the choke heater (on carburator). The Red/white wire is power. The Grey/yellow wire goes to choke.
I see 3 wires in the diagrams. They show the oil sending unit and switch as one unit, but it must be separate like the picture.
The white/red wire goes to the large round can with the stud sticking out the top. This is the oil pressure sending unit for the gauge.
Then as country bumkin said, there is a switch for the choke. That's the smaller black piece to the right of the sending unit. There is a red/yellow wire that is a power wire that goes to one terminal of the switch, and like country said, there is a grey/yellow that goes up and feeds the electric choke.
