Clearance lights
Old Jul 25, 2016 | 02:50 PM
Amphihauler's Avatar
Amphihauler
Clearance lights
I'm thinking about adding clearance lights to the roof of my cab. Was this a factory option or dealer installed. is he wiring harness still available and where did they tie into the lighting system? Whats the proper layout? I've seen five lights equally spaced and three in center group with two out board.
Old Jul 25, 2016 | 03:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 4x4Alaska
I'm thinking about adding clearance lights to the roof of my cab. Was this a factory option or dealer installed (both).
Is the wiring harness still available (no) and where did they tie into the lighting system? Whats the proper layout?
The usual arrangement.
Pic shows F700/1100 because these lamps were usually installed on BIG trucks, but could be installed on any F100/1100.
Very few parts are available for these trucks, some are available NOS, some have been reproduced.
Some of the repro parts sellers offer clearance lamps, but they are newer, won't match the originals.
IMO, look for these lamps at trucks in junkyards, then you can get the wiring harness, the switch and etc.
Old Jul 25, 2016 | 03:10 PM
Tedster9's Avatar
Tedster9
I think the # and spacing of the lights, depended on the GVWR of the vehicle. A big 600 had more than a 350 or whatever?
Old Jul 25, 2016 | 03:54 PM
6t6merc's Avatar
6t6merc
My '66 Merc was equipped with three more or less in the middle and none on the corners. I never see modern trucks so equipped so my guess is that the three light layout is no longer legal, at least where I am. They were spliced into the headlight circuit off the switch. The truck also had a momentary switch with "blink marker" on the bezel which would allow the driver to turn the lights off, I guess to signal others.
Eric
Old Jul 31, 2016 | 07:36 PM
cstempert's Avatar
cstempert
My '63 F-500 has the 3 clearance light that all appear to be factory ... also has the blink light button on the dash
Old Jul 31, 2016 | 09:45 PM
BarnieTrk's Avatar
BarnieTrk
Eric
6t6merc,
For us curious types - would you please further describe the function of the 'blink marker' switch - was it simply an on/off switch for the clearance lights?
Thanks!
BarnieTrk
Old Aug 1, 2016 | 09:16 AM
6t6merc's Avatar
6t6merc
It was a momentary switch, like a starter button of old, installed in a hole drilled in the dimple where the vent pull button was on the earlier trucks. Push and hold the button the clearance lights go out, release it and they come on. I guess it was for signalling other drivers - can't think of another reason for it.
Eric
Old Aug 1, 2016 | 09:36 AM
BarnieTrk's Avatar
BarnieTrk
Thanks for the explanation, 6t6merc!
I'm guessing that looking at the illustration provided by ND in post#2, it would be part#15443.....
BarnieTrk
By the way, this subject reminds me of when I was in Japan (~20 years ago). I asked someone why some of the bigger trucks going down the highways would have their clearance lights blinking..... I was told that when the truck exceeded the posted speed limit, their cab mounted clearance lights would blink to notify those drivers around them. Yep, no kidding......
Old Aug 1, 2016 | 09:41 AM
6t6merc's Avatar
6t6merc
Yup, and 15469 has "BLINK MARKER" on it.
Leef250
Jul 11, 2016 01:28 AM
700buck65F100
Aug 2, 2013 02:22 AM
Pdevore
6.7L Power Stroke Diesel
Sep 25, 2012 08:29 PM
XLT2.5L
1983 - 2012 Ranger & B-Series
15
Sep 22, 2009 10:12 PM
f350aggie
Jan 27, 2009 07:43 AM
