Should I buy it?
Should I buy it?
So I'm looking at a 99 F150 5.4L 4x4 Extended Cab with 139" box. 273K Miles.
Asking price from independent dealer: $1495
Issues I noticed during test drive:
Trans wont shift Into park
-Will tighten shift bar and adjust screw wheel to center
No Parking Brake
-Need to adjust rear park brake most likely
Bad Tires
-No choice but to replace ~$400
Passenger Door doesnt seem to unlock from Key Fob
-Troubleshoot
Rust
-Got a bit of rust in normal spots, some could be bad, didn't look too closely, to be expected
ABS Light Constant
-Will test and replace ABS Sensors as needed $20
CODES:
P0113 - IAT Intake Air Temperature Sensor
-Sprayed it with MAF cleaner, no change. Might replace for $20 after I clean the MAF as well and replace the air filter
P0141 - O2 Sensor
P0161 - O2 Sensor
I'd bet the Catalytic converter is bad if both say its shot.
Buy it or no?
No Parking Brake
Bad Tires
-Troubleshoot
Rust
ABS Light Constant
CODES:
P0141 - O2 Sensor
P0161 - O2 Sensor
Buy it or no?
PRETTY DANGEROUS, ESPECIALLY IF NO PARKING BRAKE.
COULD BE THE PLASTIC BUSHING AT THE LOWER END OF THE SHIFT CABLE. NEW SHIFT CABLE = $65.
No Parking Brake
PROBALLY WILL NEED ALL NEW PARKING BRAKES.
AT LEAST ON MINE THE SHOES WERE COMPLETELY GONE.
ALSO GET ALL NEW HARDWARE KIT WITH NEW SPRINGS.
AND HOPE THE REAR ROTORS ARN'T DESTROYED DURING THE REMOVAL.
Bad Tires
NEW TIRES, MOUNT/BALANCE/TAX ~$800.
-Troubleshoot
Rust
CLOSELY CHECK THE RADIATOR SUPPORT FOR RUST.
COULD BE $750 - $1000 TO REPLACE.
ABS Light Constant
JUST HOPE ITS NOT THE ABS MODULE ITSELF - $200+
CODES:
P0141 - O2 Sensor
P0161 - O2 Sensor
THOSE CODES ARE NOT REPORTING CAT PROBLEMS.
THEY ARE SAYING THE HEATER CIRCUITS FOR THE DOWNSTREAM SENSORS ARE OPEN OR SHORTED.
Buy it or no?
ONLY YOU KNOW THE ANSWER.
IT STILL HAS 273K MILES ON IT.
No Parking Brake
Bad Tires
-Troubleshoot
Rust
ABS Light Constant
CODES:
P0141 - O2 Sensor
P0161 - O2 Sensor
Buy it or no?
I feel like $1495 is a good price, but it does have 273,000 miles on it. Probably 150k overdue for an engine rebuild.
Just noted your inline responses! Thanks for the knowledge bomb. Where should I look specifically for the rust on rad supports, top or bottom usually?
Also IRT tires, I found some Firestone LE's for $86 a piece of tire rack, and I plan to mount them myself at the Norfolk base auto hobby.
Other than what I mentioned, I put it in neutral and switched between 4x4 Hi and 4x4 low and back, not sure of a good way to test it though. Does the 99 F150 still use Ford's KOER and KOEO tests?
I know on OBD1 you used to be able to pin from the engine test harness to put it in test mode.
I just purchased tires so I know your pain. I looked at Tire Rack but their shipping costs turned me off. I honestly found the lowest priced tires at Walmart.com. Some tires offer free installation if ordered online before July 27th. I went this route and got 4 General Grabber AT2 tires for just under $600 which I'm waiting to be delivered at my nearest Walmart.
So I bought it anyway, I just couldn't stop thinking about it and couldn't find anything better.
Figured out the obs sensor, and fixed the rear brakes, parking brake, and fixed the column shifter indicator. Also troubleshot the p0113 to a wiring issue. No voltage or ground at the iat.
Figured out why the obs light was on however those shavings don't give me a warm fuzzy feeling.
Thanks for the heads up. Other issues I'm tracking for next week are full front control arms ball joints upper and lower tie rods, and front brakes. I found a 14 piece front end kit on Amazon for $150. Then I need to trace the iat sensor wiring back and find where it's damaged. luckily I'm an electronics technician so that will be the easy part. Then to track down an exhaust leak. I bit off allot but so far I'm only $2000 in including the truck itself.
on
A 14 pc front end kit? What is in that and what brand?
If you plan on keeping the truck any amount of time, just get some quality parts or you will be doing it all again way too quickly.
You can get Moog Upper control arms, lower ball joints and inner and outer tie rod ends for both sides for under $250 from Rock Auto or Amazon. Another $60 or so for the idler arm (which includes the pitman arm).
Not sure what the other 5 parts would be.
This won't be a daily driver, just a home depot/dump/snowday truck.
-tires x5
-iat harness fix
-front brakes
-front rotors
-lf/rf upper control arms
-lf/rf upper ball joints
-lf/rf lower ball joints
-inner tie rods
-outer end links
-sway bar links
-oil change
-drain/fill front and rear differentials
-new low beams
-coolant flush
-replace brake fluid
-right rear e brake cable replace
-cutout / replace rocker panels
-save up for 5.4L master rebuild kit
-order 4r100 rebuild kit
-use digital osciloscope to inspect coil packs
-disassemble and clean intake iac and throttle body, lube egr pintle
-replace all vacuum hoses
-clean/grind underbody and spray rust inhibitor on everything
-iat harness fix
-front brakes
-front rotors
-inner tie rods
-outer end links
-sway bar links
-oil change
-new low beams
-coolant flush
