97 Expy ABS troubles
Old Jul 28, 2007 | 08:22 PM
jerseydog's Avatar
jerseydog
Cool 97 Expy ABS troubles
First let me say THANKS for a great site. It has helped me over and over again. This is the first time I needed to ask after searching for a while.
Now to the problem.
Every time I come to a stop the ABS kicks in at low speed (10-15mph) even on perfectly clean blacktop. The truck does stop but gets a little scary. I already replaced the sensor over the rear and I can't find anything wrong with the fronts. This all started because the ABS light was on and I replaced the sensor. There were no problems with braking prior to me changing the sensor. I disconnected the sensor and now the brakes are fine (ABS disabled). I really don't want to leave it this way, I'm coming up on inspection.
Can a difference in tire wear cause this? Thank you in advance for your help.
Tom
Old Jul 28, 2007 | 09:33 PM
jerseydog's Avatar
jerseydog
Now I know this is giving me a headache, the truck is a '99, not a '97. Sorry for the typo.
Tom
Old Jul 29, 2007 | 09:14 AM
projectSHO89's Avatar
projectSHO89
Here's an excerpt from the service manual for your symptom. Lots of possible causes.
o ABS misfire, ABS too sensitive, ABS fires on normal stop
Possible Source(s):
§ Rear anti-lock brake sensor indicator.
Action(s) to take:
§ REMOVE the rear sensor from the differential housing; INSPECT rear anti-lock brake sensor indicator.
Possible Source(s):
§ Front anti-lock brake sensor indicator(s).
Action(s) to take:
§ INSPECT for damaged teeth. INSPECT both front anti-lock brake sensor indicator(s).
Possible Source(s):
§ Sensor output.
Action(s) to take:
§ If left front anti-lock brake sensor output is out of sync, GO to «Pinpoint Test F». If right front anti-lock brake sensor output is out of sync, GO to «Pinpoint Test H». If rear anti-lock brake sensor output is out of sync, GO to «Pinpoint Test J».
Possible Source(s):
§ Sensor circuitry.
Action(s) to take:
§ GO to Intermittent Failures to test circuits 514 (YE/RD), 516 (YE/BK), 521 (TN/OG), 522 (TN/BK), 523 (RD/PK) and 519 (LG/BK).
Possible Source(s):
§ Wire insulation.
Action(s) to take:
§ INSPECT the wiring harness from the front anti-lock brake sensor knuckle to the frame and from the rear axle to the frame for worn or chafed wire insulation.
Possible Source(s):
§ Rear brake adjustment.
§ Linings.
Action(s) to take:
§ ELIMINATE the base brake system as the cause of the problem.
Possible Source(s):
§ Loose anti-lock brake sensor bolt(s).
Action(s) to take:
§ TIGHTEN the anti-lock brake sensor bolt(s) to specification.
Good luck!
Steve
Old Jul 29, 2007 | 09:34 AM
tomsc32's Avatar
tomsc32
I had the exact same problem (ABS engagement during low speed stops) on my 99. However, even though the front wheel speed sensors looked fine when I replaced them the problem went away. So did the panic stops! Good luck.
Old Jul 30, 2007 | 05:55 PM
jerseydog's Avatar
jerseydog
Thanks for the input guys, I will work on it this weekend and let you know what I come up with.
CBRR
Aug 15, 2016 05:08 AM
Cannon500
Jan 24, 2014 09:47 AM
mikulskn
Jun 26, 2013 11:23 PM
zrt600guy
1983 - 2012 Ranger & B-Series
Feb 14, 2012 04:10 PM
bronco5.8
Aug 13, 2004 10:27 AM
