Sponsored by: Real Truck
Power windows problem.
Old Jul 4, 2016 | 08:36 AM
ugh3012's Avatar
ugh3012
Passengers can roll down the power windows on front passenger door and both back doors. But, they cannot roll the windows back up. The only way they can do that is to have me do it from the driver door. The window lock button is unlocked. I am thinking some is wrong with the driver main window controller since it all goes back to it. You agree?
Old Jul 4, 2016 | 08:54 AM
Just Strokin's Avatar
Just Strokin
Most of Ford's window wiring uses the same 12v wire/source for up and down. The switch does the changing of the wire for up or down. Is odd 3 switches bad but i would check them for being dirty or corroded. Try operating the switch multiple times or added pressure on the switch to make sure contact. I would also check for corroded plug that connects the wires to the switched in the door panel.
therigwelder
Dec 27, 2014 08:39 AM
boogaloo
1978 - 1996 Big Bronco
Mar 6, 2011 12:35 PM
jeffdoerr
Sep 11, 2005 06:53 PM
Holder20
Aerostar
Feb 1, 2005 06:07 PM
3vanman
Aerostar
Dec 21, 2003 04:55 PM
