power window issues
Old Dec 25, 2014 | 06:27 PM
therigwelder's Avatar
therigwelder
power window issues
I have a 4 door f350.the right rear goes down and goes up with assistance (window slippage)from the drivers switch only. The right rear switch has no power. The right front door also does not work either, there is no power to the lt. blue/black wire. The left rear door does not work from the door switch but does work from the driver switch. The power for the power windows comes from fuse 14 a lite blue /black wire, I have power to this wire at the driver door but not the pass. why? when I run a 12v jumper to the lt.blue/ black on the pass front door the window still doesn't work so that might be a bad motor however the jumper does provide the power to the right rear via the front switch making the rear pass. work properly.is the lt blue /black wire broke somewhere or does this year truck have a G.E.M. anybody have info on how these windows are diagnosed?
Old Dec 26, 2014 | 09:00 AM
subford's Avatar
subford
No G.E.M.
Maybe the window lock switch is in the lock position.
Maybe this will help:
Old Dec 27, 2014 | 08:36 AM
therigwelder
Thanks,I have checked the window lock.I think most of my window problems on the pass. Side of my truck come from no power on the lite blue/black wire.where does this wire tie into the drivers side?does it share the same fuse ?
Old Dec 27, 2014 | 08:39 AM
subford's Avatar
subford
The lite blue/black wire (right front door) power comes from the window lock switch and the window lock switch gets its power from the same CB #14 as the other switches on the drivers door.
FERdter
May 28, 2018 12:19 PM
ugh3012
Jul 4, 2016 08:54 AM
boogaloo
1978 - 1996 Big Bronco
Mar 6, 2011 12:35 PM
twabscs
1997 - 2003 F150
Nov 24, 2006 07:38 AM
3vanman
Aerostar
Dec 21, 2003 04:55 PM
