E4OD Issues.
Old Jun 24, 2016 | 05:25 AM
Craver17111's Avatar
Craver17111
E4OD Issues.
I've got a 1996 F-250 crew cab, 4x4, 460, E4OD. Recently I made the mistake of degreasing and hosing off the engine bay and underside of the truck...
Since then I've had hard/delayed shifts, intemittant overdrive, it seems like my trans is searching for gears, occasionally it doesn't kick down. And while crusing at say around 40-50 mph it revs up and keeps a rpm of around 3k.
No check engine light so far. My overdrive light is burned out so that's no help...
So far i've reset the computer, replaced the TPS and the MLPS. No noticeable improvement.
Any help is appreciated and if more information is needed let me know...
Thanks!
Old Jun 24, 2016 | 05:46 AM
Briansshop's Avatar
Briansshop
Did you check the connector at the solenoid pack?
Old Jun 24, 2016 | 05:50 AM
Craver17111
I have not done that yet... Where is the solenoid pack located?
Old Jun 24, 2016 | 06:14 AM
thehead406's Avatar
thehead406
Passenger side of trans, large electrical harness going inside of it. Can't miss it.
Old Jun 24, 2016 | 07:16 AM
rla2005's Avatar
rla2005
Well, you can miss it because it's typically behind a heat shield.
Old Jun 24, 2016 | 10:15 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first thing to do is to check for codes. Anything else is just guessing.
Old Jun 24, 2016 | 11:24 AM
rla2005's Avatar
rla2005
Dorman 49299
~$9 USD at Autozone
Old Jun 24, 2016 | 10:00 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
inspect the ecm connector,follow it down to a large clip down below the brake booster.some lines come from the power dist box and some the ecm connector then as stated also check the bulkhead connector.
you can check for codes but they're just going to be ones that let you know you've got connection problems between the ecm and solenoids anyway,as the problem just happened when you sprayed everything with a hose.
Kanglar
Feb 1, 2017 11:05 PM
79F150400M
Aug 28, 2011 12:42 PM
Rulebreaker
Mar 1, 2009 08:48 PM
gringo
Jan 13, 2007 11:05 AM
jeepdude775
Nov 2, 2004 10:54 PM
