Delete almost done
Old Jul 1, 2016 | 04:55 AM
  #91
UGA33's Avatar
UGA33
Originally Posted by hoseclamp
Trying different tuner and tweaking custom tunes, not working. Huge lag on the bottom end, then tire's breaking loose. Not what you want for towing. Anyone with '15 and newer deletes, is the engine brake effected? Tried it today, felt nothing.
With EGR deletes, you loose the exhaust brake. It is tied into the factory EGR system. Only one tuner I've read about is able to keep the function.
Old Jul 1, 2016 | 07:33 AM
  #92
System's Avatar
System
Prolocutor
That sucks Mike. All that work and so many issues. I know exactly how you feel. All that work at the XLR plant and I've still got the main issue I went there with. Ugh.
Josh, what's the tuner that keeps the brake? Spartan?
Old Jul 1, 2016 | 08:44 AM
  #93
UGA33's Avatar
UGA33
They are working on it. Some trucks can retain it, some won't. Sounds crazy, but that is the case. Cale Thompson tuning through an X4 is about the only one with a functioning "press the button" exhaust brake at the moment.
Old Jul 1, 2016 | 09:41 AM
  #94
hoseclamp's Avatar
hoseclamp
Sounds like I'm going back to full emissions. Exhaust brake is important.
Down side of this, won't see improved mpg from regens going away. Up side, back to windex smell lol, and it made awesome power anyway.
Old Jul 1, 2016 | 10:07 AM
  #95
System's Avatar
System
Prolocutor
Well, that blows. Do you have someone to buy all your goodies? That's a lot of new goods to put on the shelf...
Old Jul 1, 2016 | 10:11 AM
  #96
hoseclamp's Avatar
hoseclamp
I'll be keeping the BD components, the ccv egr delete I'll arrange to sell. The intake never worked, SCT didn't cure anything so it goes back also. Plus I'm not even in town while the boys tear back into it. I get home and it's all fixed. All is good, golf and a red TTV8 ragtop Benz waiting for me. Life is good
Old Jul 1, 2016 | 10:16 AM
  #97
System's Avatar
System
Prolocutor
Enjoy brother! Chicago NW KOA now. Pick up the girls at the airport this afternoon. Then up to Wisconsin Dells on Sunday. Life is good indeed.
Old Jul 1, 2016 | 10:59 AM
  #98
UGA33's Avatar
UGA33
If you have SCT, give Cale a call. He has goon tuning and you could keep the exhaust brake.
Did you ever find out the issue?
Old Jul 1, 2016 | 11:21 AM
  #99
hoseclamp's Avatar
hoseclamp
Never fixed the turbo lag with new plumbing no, it's bad, then hits like insanity. I'm getting the guys to hook up a trailer and try out the engine brake while I'm gone. I need that more than better mpg and better power.
Old Jul 1, 2016 | 01:10 PM
  #100
cappa's Avatar
cappa
Curious who's tunes you were running on the sct. Seems like a huge waste of money and time to just go back stock. There are other guys out there running this setup so i'm sure it can be done. Has to be a tuning issue.
Old Jul 1, 2016 | 01:13 PM
  #101
System's Avatar
System
Prolocutor
I agree Mike. I'd at least try calling Spartan...
Old Jul 1, 2016 | 01:40 PM
  #102
hoseclamp's Avatar
hoseclamp
Spartan doesn't have this intercooler setup and plenum, no canned tune will make this work, and a few custom by the looks of it also. It needs a dyno IMO. It behaves like it doesn't know what to do unless under heavy boost is being thrown at it. Like it doesn't want to flow until it has no choice. It was stumbling and reverbing with a loose intake coupler, I expected that, but it's also done it with 100% no leaks anywhere. That I didn't expect. It isn't flowing correctly down low on my truck is what that says. Changed MAF also just in case, no difference. The designer has this system on other truck, but I don't know what is the difference, where it works on the others and not mine. We try a few things next week. Maybe go to a basic delete setup, stock tubing and intake, I believe it would work then, but will I have engine braking.
Old Jul 1, 2016 | 03:01 PM
  #103
UGA33's Avatar
UGA33
I guarantee Matt at Spartan could tune it out if it's tuning related. What setup do you have?
Old Jul 1, 2016 | 03:04 PM
  #104
UGA33's Avatar
UGA33
I went back to your first post with the pics. Was the temp sensor that's in the cold side pipe put back in the loop?
Old Jul 1, 2016 | 04:09 PM
  #105
hoseclamp's Avatar
hoseclamp
I have something that unless you bought it from AMDP in Victoria BC, no one else has it.
