Stranded help!
Old Jun 17, 2016 | 08:17 AM
Rsiebert's Avatar
Rsiebert
Stranded help!
Hey guys good morning, I'm in desperate need of some suggestions here. I have a 2004 6.0 and I seem to have lost ignition. I'm stranded in a parking lot with the hot sun rising fast. Ok so I'm backing out of a parking spot and she just dies on me. Checked all fuses twice. Half a tank of fuel, it seems to have lost ignition. Any suggestions would be greatly appreciated
Old Jun 17, 2016 | 08:56 AM
Carlosfj80's Avatar
Carlosfj80
Do you still have power? Lights and radio are still working?
Old Jun 17, 2016 | 09:19 AM
Rsiebert's Avatar
Rsiebert
Yes. All seems to be fine.
Old Jun 17, 2016 | 09:22 AM
Rsiebert's Avatar
Rsiebert
I took the fuel filter cap off and she seems to be pumping fuel just fine.
Old Jun 17, 2016 | 09:28 AM
Rsiebert's Avatar
Rsiebert
When cranking....should I be reading oil pressure?
Old Jun 17, 2016 | 10:28 AM
Transplanted's Avatar
Transplanted
Fuel shut off switch.Behind kick panel on passengers side..Maybe
Old Jun 17, 2016 | 10:48 AM
silverbullet6oh's Avatar
silverbullet6oh
No, you should not see any oil pressure until after start. It delays pressure reading after start about 1 second (if your talking about the dummy gauge).
Old Jun 17, 2016 | 10:51 AM
silverbullet6oh
When you say "it seems to have lost ignition", does that mean the engine is turning over, and just not firing. That what that means to me..... Some people describes things differently. Just want to clarify.....
Old Jun 17, 2016 | 12:05 PM
Rsiebert's Avatar
Rsiebert
That is correct yes
Old Jun 17, 2016 | 12:10 PM
KDAVID1's Avatar
KDAVID1
Do u have scan gauge or similar for live data---could have internal hpo leak, low cranking rpm, bad ficm,etc etc.
Old Jun 17, 2016 | 01:15 PM
silverbullet6oh
This was going to be my next question. I sure hope he does, or else its anybody's guess with what's wrong.
Old Jun 17, 2016 | 06:23 PM
Rsiebert's Avatar
Rsiebert
No I do not. Well I'm still here in the parking lot. I believe to have found an issue. I removed the oil filter housing cap and filter and cranked to check for oil entry. I have none it's bone dry in there. So my question now is, may this be a sending unit or do you think I need a pump?
Old Jun 17, 2016 | 07:51 PM
BLADE35's Avatar
BLADE35
How many Miles
Check the LPOP Regulator
sometime the spring get stuck
Was is Reved upon shutdown?
Old Jun 17, 2016 | 07:52 PM
BLADE35's Avatar
BLADE35
its down by the Dampener pulley
Hit a Hard Bump?? Recent
the Pickup maybe cracked at a Joint
Or worse case Lifter Killed it and its the most Common case of LPOP Failure engine
Old Jun 17, 2016 | 08:40 PM
Rsiebert's Avatar
Rsiebert
378,000 miles so from my understanding there is really no lower pump...it is gears on the crank and grooves in the cover that supply oil to the cylinders??? Is this correct? And if I have no oil in or coming to my filter housing do the grooves also supply this? Or does the sending unit help with this? Regulator?
