Stranded help!
Old Jun 17, 2016 | 08:43 PM
Rsiebert's Avatar
Rsiebert
Oh and no it wasn't reverse at all it was actually running for about 30 seconds before it just stalled out.
Old Jun 17, 2016 | 08:51 PM
BLADE35's Avatar
BLADE35
yes gears are the LPOP
LPO is all mechanical pump and regulation (No electronics Controlling)
Old Jun 17, 2016 | 08:56 PM
BLADE35's Avatar
BLADE35
https://www.ford-trucks.com/ford-man...eTableBook.pdf
Old Jun 18, 2016 | 12:30 PM
BryanStein's Avatar
BryanStein
Id suspect regulator. It would take a carostophic lpop failure to deliver absolutely zero oil to the filter housing.
Old Jun 18, 2016 | 01:06 PM
Rsiebert's Avatar
Rsiebert
I just checked the regulator. All seems fine
Old Jun 18, 2016 | 08:27 PM
Rsiebert's Avatar
Rsiebert
Ok so I must not be building pressure enough to open the regulator and let oil flow. Is this correct? If so is the lower gerotor gear the only thing that builds the pressure in the lower?
Old Jun 18, 2016 | 08:39 PM
BLADE35's Avatar
BLADE35
Yes
Most pull the LPOP at this point
and prey its not imprinted with a Needle bearing must be smooth
Old Jun 18, 2016 | 08:54 PM
Rsiebert's Avatar
Rsiebert
Just got done tearing the whole top end apart down to the cooler. Only thing I found was a bad screen. Looked like the original screen it was barely there. Just disintegrated. Put everything back together checked for oil into the filter housing....filled half way and stopped. That was it.
Old Jun 18, 2016 | 09:05 PM
BLADE35's Avatar
BLADE35
well that's Good news
theres a Drain in the oil filter house did you have it pressed down??
the filter hold it down when all together
You LPO sounds good
pull the IPR now it got trashed I suspect from broken sump screen
Old Jun 18, 2016 | 09:35 PM
Rsiebert's Avatar
Rsiebert
Already changed the ipr...$300. I did that first.
Old Jun 18, 2016 | 10:04 PM
robs97z28's Avatar
robs97z28
We need to stop guessing. We need some good info, plz buy yourself a SGII from autozone. With this tool you cn figure out what is wrong. one of the things it cant read is fuel press.
Old Jun 18, 2016 | 10:38 PM
Rsiebert's Avatar
Rsiebert
Please tell me about the cooler bypass and the filter bypass. Where are these located and if they have no pressure could this be an issue? Thanks for the help by the way.
Old Jun 18, 2016 | 10:41 PM
  #28
robs97z28's Avatar
robs97z28
you have LPO pressure. the LPO feeds oil to the HPOP. if the HPOP is not getting oil from the LPO, the engine would not fire up at all. not even for 30 sec.
Old Jun 18, 2016 | 10:51 PM
  #29
Rsiebert's Avatar
Rsiebert
It doesn't fire at all it's like it just quit firing I have fuel and no fire. It was running then stalled.
Old Jun 18, 2016 | 10:55 PM
  #30
robs97z28's Avatar
robs97z28
correct, meaning you are going oil to the hpop. I would look at ficm voltage of ficm relay, or you have a hpop leak
