Stranded help!
Old Jun 24, 2016 | 04:25 PM
  #61
Per4mance's Avatar
Per4mance
Did ya clean the oil pressure regulator out? It might have junk in it
Old Jun 24, 2016 | 04:41 PM
  #62
Rsiebert's Avatar
Rsiebert
I have cleaned the regulator out like three times only found crud the first time
Old Jun 24, 2016 | 04:43 PM
  #63
Rsiebert's Avatar
Rsiebert
So have my .25 volt key on engine off. This means my readings are true is this correct.
Old Jun 24, 2016 | 04:44 PM
  #64
Rsiebert's Avatar
Rsiebert
The hpop needs to be working to create pressure for the lpop? Is this correct?
Old Jun 24, 2016 | 05:21 PM
  #65
Rsiebert's Avatar
Rsiebert
Ok so guess I'm going back in to fetch the hpop. What are the details on this pump? Is it cleanable/rebuild able?
Old Jun 24, 2016 | 05:50 PM
  #66
163junk's Avatar
163junk
LP pump feeds HPOP You need oil in filter to feed HPOP. Page 22: Lubrication System
Old Jun 24, 2016 | 06:09 PM
  #67
Sparky83's Avatar
Sparky83
Originally Posted by Rsiebert
I just don't understand why I still have no oil pumping into my filter housing.
ive read in other no start or oil pressure threads that when the LPOP is replaced it can be a PITA to get it to prime sometimes... especially when its dry (ie new).. there is supposed a procedure for priming it but cant remember what it is... might try asking (Sean) Yahiko... i think he has the priming procedure for it...
Old Jun 24, 2016 | 06:55 PM
  #68
nmclella's Avatar
nmclella
Some people just pour some oil in http://www.powerstroke.org/forum/6-0...1068378?page=1
Old Jun 24, 2016 | 07:14 PM
  #69
BLADE35's Avatar
BLADE35
a working truck will fire after an Oil Cooler in 2 minutes of cranking with NO Pre fill
I fill the standpipe my start is almost instant when filled right
How long have you cranked
Old Jun 24, 2016 | 07:17 PM
  #70
BLADE35's Avatar
BLADE35
A HPO problem can and will look like a LPO Problem
The only catch is you found LPO catastrophic fail
you need LPO to fill the Oil Filter house before you move on to anything else you maybe wasting money at this point on anything HPO
unless you pull the oil cooler and found sump screen ripped
Old Jun 24, 2016 | 07:20 PM
  #71
Rsiebert's Avatar
Rsiebert
Ok got the hpop off...does anyone know the priming procedure for the lpop? Is there any way to test the hpop for failure?
Old Jun 24, 2016 | 07:25 PM
  #72
BLADE35's Avatar
BLADE35
does the gear spin easy
was it binding
Initial HPOP testing is done in vehicle
Old Jun 24, 2016 | 07:27 PM
  #73
Rsiebert's Avatar
Rsiebert
Yes the screen was disintegrated. Oh I've cranked most of the day....lol
Old Jun 24, 2016 | 07:28 PM
  #74
Rsiebert's Avatar
Rsiebert
Only reading 8-9 psi then maybe 10 when cranking
Old Jun 24, 2016 | 07:31 PM
  #75
BLADE35's Avatar
BLADE35
Pull the IPR
check the screen and Clean the Valve
Push up on valve it should move about 1/8" under fair amount of force
