Injector/ HPOP and oil
Old 06-01-2016, 11:08 AM
mcali2's Avatar
mcali2
mcali2 is offline
My question is; is the oil in the HPOP that works the injectors a different oil or oil supply from the engine oil? If so what kind of oil and how often do you check it and or change it? I believe I saw a video of a person checking the HPOP oil level from the top of it by removing a bolt...????
Old 06-01-2016, 11:10 AM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
It's filled with engine oil, and supplied from the main low pressure oil pump. you'll never have to change it separately, or even check the level.
Old 06-01-2016, 11:34 AM
fordpride's Avatar
fordpride
fordpride is offline
Old 06-01-2016, 11:35 AM
fordpride's Avatar
fordpride
Did you watch the "change your hpop oil" video? Lol
Old 06-01-2016, 11:46 AM
mcali2's Avatar
mcali2
mcali2 is offline
I don't remember. Dang that's messed up someone would do that.
Old 06-01-2016, 11:54 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
don't forget to change out your winter air for summer air in your tires
Old 06-01-2016, 12:25 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,192 Likes on 818 Posts
now that there was funny.
But in reality you can change it will it make a difference, yes oil wont turn tar black, I for one do it at work and most of the 7.3 trucks are still sporting the stock injectors with stock O rings with trucks with 260k- 390k and most have never seen fuel additives.
Can I prove this works no, im no scientist, but real word test has shown that injectors have lasted longer.
People will make fun of us who do it, but if I can get 400k out injectors dam right ill keep doing it
Old 06-01-2016, 02:05 PM
mcali2's Avatar
mcali2
mcali2 is offline
already ahead of that. I still have air in the tanks from last fall so I will use it and be ready for 2 seasons.
Old 06-01-2016, 02:16 PM
knottyrope's Avatar
knottyrope
what happens when you leave the window open in the men's room
Diesel 724
16
07-08-2020 01:22 PM
firemediceric
58
11-10-2014 06:40 PM
A/Ox4
66
11-03-2013 09:04 PM
jccapri
20
12-21-2012 09:35 PM
ozzy460
02-03-2011 12:01 AM
Quick Reply: Injector/ HPOP and oil
